toyota parking lights
rugerm44
Member - Posts: 24
Posted: October 05, 2004 at 5:49 PM / IP Logged
I have a 2004 tacoma ext cab and was wondering where is the best place to tap into the parking lights.Toyota has a parking light relay which is triggered by a negative ground.What color wire and where is it located?Thanks
ruger
Teken
Gold - Posts: 1,492
Posted: October 05, 2004 at 6:00 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / TACOMA / 2004 / Remote Start
12volts white (40A), wht/red (30A)   +   ignition harness
Starter black   +   ignition harness
Second Starter N/A
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory N/A
Keysense lt. GREEN/ red   -   ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
Power Lock gray   -   front of fuse box, 22 pin plug
Notes: These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Power Unlock purple   -   front of fuse box, 22 pin plug
Lock Motor blue/white   5wi DKP, 12 pin plug in pin 10
Unlock Motor blue   5wi DKP, 12 pin plug in pin 11
Parking Lights+ green   +   back of fuse box, 12 pin plug
Parking Lights- PURPLE / red, red, or yellow   -   front of fuse box, 22 pin plug
Hazards same as turn signals
Turn Signal(L) green   +   steering column
Turn Signal(R) GREEN / WHITE   +   steering column
Reverse Light RED / black   +   under driver seat, 13 pin plug
Door Trigger see notes   -   front of fuse box, 22 pin plug
Notes: The driver door trigger is green, the front passenger door is GREEN / WHITE, and the rear doors is YELLOW /GREEN. Use all three wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer NOT blk/yel, blk/red, or brn   ac   any ignition coil
Notes: Vehicles with a tachometer in the instrument cluster can also use a lt. GREEN/ black wire for tach. On the 4 cyl it is at the data link connector to the right of the steering column. On the V6 it is at the igniter on the passenger fender, below the air filter box.
Wait to start N/A
Brake Wire GREEN / WHITE   +   brake pedal switch
Parking Brake GREEN / WHITE   -   parking brake switch
Horn Trigger GREEN/ red   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Teken
Gold - Posts: 1,492
Posted: October 05, 2004 at 6:02 PM / IP Logged
Toyota Tacoma 2004
Remote start / Security / GPS
Wire/Function Colour Location/Description Polarity
12 VOLTS White or WHITE/ red Ignition switch harness +
IGNITION BLACK / YELLOW Ignition switch harness +
IGNITION 2 BLACK/ red Ignition switch harness +
ACCESSORY Runs with ignition wire
STARTER Black Ignition switch harness +
TACH See notes*
FUEL INJECTOR Opposite from BLACK/ red At any injector on engine AC
LOCK BLACK/ blue In driver's kickpanel -
UNLOCK RED / yellow In driver's kickpanel -
DOORPIN SEE NOTES**
BRAKESWITCH GREEN / WHITE At switch above brake pedal +
PARKLIGHTS Green At bottom of fusepanel +
HAND BRAKE GREEN / WHITE At switch on handbrake lever -
HORN GREEN/ red At steering column -
CLUTCH SWITCH BLACK/ white At switch on top of clutch pedal TYPE 1
DRIVER WINDOW UP Blue / YELLOW At master window switch REV POL
DRIVER WINDOW DOWN Blue/green At master window switch REV POL
PASSENGER WINDOW UP RED / black At master window switch REV POL
PASSENGER WINDOW DOWN RED / green At master window switch REV POL
HEADLIGHTS RED / blue or RED / green At light switch harness -
REVERSE LIGHTS RED / black In driver's kickpanel +
DIMMER WHITE/ green At harness behind dimmer switch +
VSS WIRE GREEN/ orange*** At ECM behind glovebox***
KEY SENSE Lt.GREEN/ red Ignition switch -
Vehicle notes
* On the 2.4L and the 2.7L engine, there are 2 coils on the left front of the engine. Use the BLACK/ BLUE or BROWN / YELLOW for a 2 cylinder signal. On the 3.4L engine there is a coil per cylinder. Use the wire opposite from the BLACK/ RED at any of the coils. With any of the engines you can also find a BLACK tach reference at pin-15 of the 26-pin connector on the ECM behind the glovebox.
** GREEN (driver's door), GREEN / WHITE (passenger door), YELLOW /GREEN (rear doors). All 3 wires are found in a 22-pin connector on the front of the fusepanel under the dash. Isolate with 1N4001 diodes if connecting together.
*** The GREEN/ ORANGE vss wire is located on the ECM behind the glovebox. On the 2.4L and 2.7L, it's at pin-8 of the 22-pin connector. On the 3.4L, it's at pin-12 of the 28-pin connector.
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
©2002 Autoland All rights reserved
Printed at: 10/5/2004 7:00:28 PM
rugerm44
Member - Posts: 24
Posted: October 05, 2004 at 8:17 PM / IP Logged
Thanks alot.That about covers everything.
ruger
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
