no mid bass on rear speakers
losboricua
Copper - Posts: 135
Posted: November 13, 2004 at 11:25 PM / IP Logged
ok my friend from work has a 96 acura 1.6le(canadian car i never heard of it) it is a four door. ok he just got a new panasonic headunit install in his car and there is no mid bass comin out of the bak speakers just vocal.  i looked trough the manual and the player to see ifit had a built in filter and it didnt had anything.  i looked at the connection of the speakersand i saw that the speaker looked like it has two different terminals. like one for the woffer and one for the tweet.  one of the cable to one of the connection was cut off.  are the factory speakers in his car lower than 4 ohms so they had to cut one coil of or somethin.  im very confuss. any ideas????
i think this is the model of the cd player he got http://www.thezeb.com/p-Panasonic-CQ-C3300U-CD-MP3-Stereo-Receiver-108725.htm
2015 Hyundai Genesis Ultimate Black on Black
Tinted Windows, Fogs, Roof Spoiler, ARK Springs, Ruff R1 20's Staggered
auex
Platinum - Posts: 5,041
Posted: November 13, 2004 at 11:58 PM / IP Logged
Really easy, check the phase of the speakers. Fade to rear and adjust the balance all the way to the right or left, if bass appears then reverse the leads on one of the speakers.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
losboricua
Copper - Posts: 135
Posted: November 14, 2004 at 12:04 AM / IP Logged
oh so just because the installer put the positive on the negative and negative on the positive??? i will try that next time i see him.  thanks
dragonrage
Copper - Posts: 193
Posted: November 14, 2004 at 12:09 AM / IP Logged
From your description, it sounds like the speaker was meant to be biamped. But I won't say that's definite w/o looking at the speakers....
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
auex
Posted: November 14, 2004 at 12:27 AM / IP Logged
I did't catch the part about wires at a terminal being cut. All you should have to do is wire the missing terminal and you should be good to go. Again not knowing what speakers they are or seeing them it is hard to say knowing this.
losboricua
Copper - Posts: 135
Posted: November 14, 2004 at 12:44 AM / IP Logged
oh ok i will hopefully look into that tomorrow and try that.  i didnt want to hook that wire up not knowing if it will be too low of a load an end up burning the amp in the cd player.  hey auexif u have aim im at losboricua18 i got a question about my car alarm since by judgin from ur sig u know alot about car alarms
dragonrage
Copper - Posts: 193
Posted: November 14, 2004 at 1:05 AM / IP Logged
Well, you can use a multimeter and see what the DC resistance of the speaker is... It should be about 4 ohms to be hooked up to a HU. If each terminal is 4 ohms, you'd ideally have to get a crossover or new speakers. If each is 8, then put them in parallel to make 4
HU: ?
Speakers: ?
Amps: ?
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
