Fabric for enclosures
Nine5Eclipse03
Posted: November 14, 2004 at 5:38 PM / IP Logged
I just need to know what kind of fabric i need to cover my fb enclusure with, I have the mold out, and the two rings mounted with the 2x4, i just need to cover it. I've heard that fleece is what most use, but is there any type of special kind i should get so it stretches perfectly?
Also, is 2 layers, and tons of resin enough for the mold? I'm dropping in a 12" rockford p3.
Thanks guys.
auex
Platinum - Posts: 5,041
Posted: November 14, 2004 at 6:26 PM / IP Logged
You can use any stretchy fabric. All you should need for the "mold" is one layer. After that the rest of the layers should be fiberglass mat or cloth.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
kidtransam
Copper - Posts: 99
Posted: November 14, 2004 at 9:18 PM / IP Logged
Just ask for `sweatshirt fleece`. Thats what I use and its great..stretches well and soaks up alot of resin.
With a torch and a big enough hammer...it WILL friggin fit!!
boxmaker85
Silver - Posts: 433
Posted: November 14, 2004 at 11:12 PM / IP Logged
Yeah just general fleece works.  Cheap and effective.
Nine5Eclipse03
Posted: November 16, 2004 at 12:05 PM / IP Logged
Ok, I need some advice. I have two 12" Rockford punch stage 3's, 1000 watts max, 500 RMS. Powering both of those is 1 Kicker DX700. What would be louder? Hooking up the kicker to both of the subs, or just using the whole amp to power one of the punchs? I almost have my box done, its for one sub, and im wondering if i want to built another for the other sub, or if i should wait until i get another Kicker DX700. Any ideas?
Thanks guys
boxmaker85
Silver - Posts: 433
Posted: November 16, 2004 at 10:24 PM / IP Logged
Run one sub in two ohms.  One sub for one amp.  Those P3 can handle 700 watts.  Make sure gain is properly set though.  So wait for the other DX700.  Then push both amps and both subs.  Rock it.
fiznasty
Posted: November 17, 2004 at 8:16 PM / IP Logged
wat up everyone im new and i was wondering wat type of screws do u use to hold the fiberglass mold to the car
