Check Gauges
The Rock
Member - Posts: 30
Posted: December 06, 2004 at 11:40 AM / IP Logged
Hey,
I have a 99 Camaro and just installed the viper 791xv alarm on it, like 4 months ago.  I last light while I was driving the like came on CHECK GAUGES,  so I am wondering if it has something to do with the remote start or could it be the battery, because it also shows me that errow that battery is on those red little dots, and it's not suppost to be there.
Thanks,
Let me know if anybody know,
I will take it to a mechanic like in a day or two.
Teamrf
Gold - Posts: 1,031
Posted: December 06, 2004 at 11:55 AM / IP Logged
Was your gas tank low? That usually means the gas in the car is low.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
The Rock
Member - Posts: 30
Posted: December 06, 2004 at 11:57 AM / IP Logged
Thanks for the fast resonse Teamrf, no gas is half full,  and I had it less than that.  Thanks again.
auex
Platinum - Posts: 5,041
Posted: December 06, 2004 at 1:40 PM / IP Logged
Check gauges light means exactly that, check your gauges. You might have been running hot, low on gas, low voltage, or oil pressure. If it was the check engine light then that would be something differant.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
daniel2002p
Silver - Posts: 524
Posted: December 06, 2004 at 3:59 PM / IP Logged
It is probably the charging system, since the batt is close to red.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
The Rock
Member - Posts: 30
Posted: December 06, 2004 at 4:13 PM / IP Logged
Ok, Thanks Auex and Daniel2002p.  I will let you know tommorow what is it.
Thanks again.
The Rock
Member - Posts: 30
Posted: December 07, 2004 at 9:45 AM / IP Logged
Well, as I was driving last light, the car turned off, just turned off, I was lucky it was right around the corner of my house.  So, I took booster cables and try to turn it on with my brother's car, and bingo, the car started right away, and check gauges light wasen't there no more.  So, I think it's the battery, maybe ran out.  I will get a new battery today and I will see.
auex
Posted: December 07, 2004 at 4:06 PM / IP Logged
If the car dies while running then your alternator is at fault. Get it checked immediately.
archemedes
Copper - Posts: 172
Posted: December 07, 2004 at 4:31 PM / IP Logged
yep alternator, and battery they hate being drained
The Rock
Member - Posts: 30
Posted: December 07, 2004 at 4:49 PM / IP Logged
guys, your are right, it was the alternatior, so I had to get a new alternator and a new battery and bingo.  It's good and running now.
Thanks for the help.
