Primer before spraying fiberglass?
Chiana
Member - Posts: 35
Posted: December 22, 2004 at 10:47 PM / IP Logged
I am working on a fberglass project.
http://www.electronicimpulse.net/~vissagoth/jeep/Albums/RD/index.htm
It is almost done. DO I need to primer the fiberglass before putting the top coat on?
-Chris
Carbonb
Copper - Posts: 113
Posted: December 23, 2004 at 12:42 AM / IP Logged
Yes, always primer if you are going to paint.
Chiana
Member - Posts: 35
Posted: December 23, 2004 at 12:54 AM / IP Logged
What  type of primer?  Anything special, or will any primer do?
Carbonb
Copper - Posts: 113
Posted: December 23, 2004 at 1:17 AM / IP Logged
Well, I don't think it matters if you are already ready to paint.
To be safe though, I would probably get a high build primer, to fill small pin holes then wetsand with around 400 grit. Then you should reprimer and then paint.
realitycheck
Silver - Posts: 751
Posted: December 23, 2004 at 9:15 AM / IP Logged
Thats pretty cool dude, I like the idea hope it works out for you! Let us know how it works once you get it in. And yeah I agree with what Carbonb said!
Chiana
Member - Posts: 35
Posted: December 23, 2004 at 10:15 AM / IP Logged
I'll do an update with installed pics once its done.  So farI am really happy with how it has come out... being my first fibelglass project like this.
Chiana
Member - Posts: 35
Posted: December 28, 2004 at 6:47 PM / IP Logged
Is there a special primer just for fiberglass, or will any primer work?
auex
Platinum - Posts: 5,041
Posted: December 28, 2004 at 8:23 PM / IP Logged
Ok, hold on. Are you spraying fiberglass resin or paint? If fiberglass to fiberglass then just sand so that the resin has something to hold on to. If paint then yes prime it. Or even better use colored gel coat and wet sand.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Chiana
Member - Posts: 35
Posted: December 28, 2004 at 8:31 PM / IP Logged
I am spraying it with paint, not gel coat.  I need it to match the interior so semi gloss should match perfectly.  I know I need to primer, but is there a special primer for fiberglass, or will just any primer work?
dowmace
Member - Posts: 23
Posted: December 29, 2004 at 1:18 PM / IP Logged
just use a high-build primer from autozone in a rattle can,
