2000 caravan no unlock
hardwareman
Posted: January 02, 2005 at 10:08 PM / IP Logged
2000 caravan / bulldogsecuity 500deluxe rs/keyless entry Doors lock w remote but no unlock. I have tries a 665 ohm resistor for alarm applications and the 250 ohm no alarm and neither works. It does have alarm as far as I can tell (but no transponder key) The unit does send a negative pulse.. any help here folks?
ras
jcap
Member - Posts: 41
Posted: January 03, 2005 at 12:41 AM / IP Logged
resistance for unlock for 2000 caravan is 2.0kohm.
jcap
hardwareman
Posted: January 03, 2005 at 12:49 PM / IP Logged
thanks - will try that however the dodge manual gives 249 ohm w/o alarm and 665 with alarm. I will try the 2k you suggest    tx        hardwareman
ras
gus1
Gold - Posts: 1,013
Posted: January 03, 2005 at 7:40 PM / IP Logged
And use relays to provide a solid ground for the multiplexed doorlock system.  Over on the left in the blue bar, you will find various "how to's", there is a part for relays. You need to wire up 2 relays for negative output to drive the doorlock outputs properly.
Gus
mike7330
Member - Posts: 8
Posted: January 03, 2005 at 9:18 PM / IP Logged
Hey hardwareman, you are on the right track, but there is a problem. Here it is.
With alarm: Use a 665ohm resistor for the unlock pulse, and a 4020 ohm resistor for lock.
W/O alarm: Use a 249 ohm (I used 220 and it worked fine) resistor for unlock, and a 1.5K ohm resistor for lock.
The unlock pulse always need the smaller number ohm resister. oh, and I installed this just last week, so I know this works for sure. The 249 and 1.5k I used.
This system need 2 different resistors to operate, as it is a single wire system, and use relays for better performance.
