1988 ford mark 7 remote start wiring?
Welcome Guest :)
boucher911
Member -
Posted: January 26, 2005 at 1:55 PM / IP Logged
If anyon has the wiring info on a 1988 Ford Mark 7 please send me the link , i need to install a remote starter thank u
DaBouch
jaurora
Silver -
Posted: January 26, 2005 at 2:28 PM / IP Logged
Lincoln | Mark VII/LSC | 1988-1992 |
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | RED / LIGHT BLUE | IGNITION SWITCH HARNESS |
Ignition #1: | | RED / LIGHT GREEN | IGNITION SWITCH HARNESS |
Ignition #2: | | GRAY / YELLOW | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | BLACK/ LIGHT GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | LIGHT GREEN | (+) AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | D GREEN/ YELLOW #-#, | TAN / YELLOW #-# AT ECM * |
Parking Lights: | | BROWN | (+) AT LIGHT SWITCH OR AT FUSE BOX |
Headlights: | | RED / YELLOW | (+) AT HEADLIGHT SWITCH |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Engine Control Module (ECM) Located In Passenger Kick Panel. ** See Note #127 - Ford Ignition Switch Connection Diagram. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | YELLOW AND YELLOW | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | DARK GREEN/ PURPLE | (-) IN EITHER KICK PANEL |
Dome Lights/Superv: | | BLACK/ LIGHT BLUE | (+) AT PIN SWITCH OR COURTESY LIGHT |
OEM Horn: | | YELLOW/LIGHT GREEN | (-) STEERING COLUMN HARNESS |
Power Lock: | | PINK / YELLOW | DRIVER'S KICK PANEL *** |
Power Unlock: | | PINK/LIGHT GREEN | DRIVER'S KICK PANEL *** |
Trunk Release: | | PURPLE / YELLOW | (+) AT RELEASE SWITCH |
Alarm Input Wire: | | BLACK/ LIGHT BLUE | (+) AT PIN SWITCH OR COURTESY LIGHT |
Notes: | | *** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram. |
MECP certified (If it really means anything)
Jeremy
boucher911
Member -
Posted: January 26, 2005 at 5:58 PM / IP Logged
thanks man i got to install one in my buddies grandfathers car hahahaha should be fun
DaBouch
Thursday, June 6, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
