finally, some pics of the new system
stevdart
Platinum - Posts: 5,816
Posted: March 17, 2005 at 10:41 PM / IP Logged
projectprotege wrote:
the guy who put the mic in my car said it was the loudest car by far hes heard since last spring. lol
uh HUH.  NOW you're talkin'.  The good old meter will lay to rest those seeds of doubt that get planted in your head....every time.
projectprotege
Copper - Posts: 112
Posted: March 17, 2005 at 11:34 PM / IP Logged
holy sh*t, i just bridged it and WOW, i cant even stand having it up all the way. im very happy with it now :D
i know what you mean stevdart, i was telling him how i didnt like the sound. you should have seen his face when the bass hit. he wasnt expecting it to be that loud haha.
projectprotege
Copper - Posts: 112
stevdart
Posted: March 18, 2005 at 7:22 AM / IP Logged
(I'll post the plans up again for those who want to see how this project was figured out, originally posted in this thread in the General Discussion forum:)
Here are the results.  I figured out volumes and measurements for this project (may do this some day myself...) and I will outline it here.  All dimensions here are OD (outside dimensions).  The two boxes have the same common height at 15", the same common width at 36", and have a common base height of 3 3/4".  The face angle of each is 45 degrees, and saw angle cuts are listed here for the angles.  The face angle cuts are 45 degrees, but the angle on the rear of the front box has angle cuts of 16 and 74 degrees.  The lengths of the hypotenuses are 14 7/8" for each face and 10 7/8" for the backward angle.  There is a center top flat depth of 2 3/4" on the front box (I figured the air space directly below it at 1 1/2", so let the final size be determined when you assemble the angled sides), and a rear top flat depth of 3 1/4" on the rear box.  The depth of the front box is 16 1/2"; the depth of the rear box is 14 1/2".  The two boxes combined make 31" depth.
Volumes were determined using 3/4" MDF.  A solid 3/4" MDF center baffle is placed dead center of each box to separate the subs.  I figured subwoofer displacement ( or lack of, in the rear box) with these measurements.  Each sub will have 1.2 cubic feet of air space (displacement already figured in).  Build the boxes exactly to these specs and you will be good to go...(but check for fit in your car first).  Just an inch different somewhere will throw the balance off....and in your case where you are powering all subs with one amp channel, we want the volumes to be the same for each sub.
In this pic, the subs have been resized to be truer to scale and the base has been raised.  But I didn't redraw the boxes entirely, so the rear box will actually extend forward a bit more than is shown, and the front box will be somewhat compacted with a steeper backside angle than is shown (but the "cut angles" listed are correct)...
finally, some pics of the new system - Page 3 - Last Post -- posted image.
Using the same side view, the interior space is divided into rectangles and wedges and calculated to get total volume for each box.  Measurements below the pic are interior, and the results are listed below.
                   1.0766                                           1.0766
                     .307                                                .5127
                     .307                                                .76
              ___.879___                                    _________
                  2.569   ft^3                                     2.35   ft^3
         -   ___.16___  sub displacement  +__.04___   cone area
                  2.41  ft^3                                          2.39  ft^3
The middle divider and all sides have already been deducted, so you just divide these box volume totals by two to get 1.2 ft^3 per sub.
Calculators used:
https://www.the12volt.com/caraudio/boxcalcs.asp#wed
https://www.the12volt.com/caraudio/boxcalcs.asp#rec
http://www.1728.com/pythgorn.htm
projectprotege
Copper - Posts: 112
Posted: March 18, 2005 at 10:04 AM / IP Logged
awsome plan if you ask me finally, some pics of the new system - Page 3 - Last Post -- posted image.
Page of 3
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
