The best subwoofer
comp123
Member - Posts: 11
Posted: March 22, 2005 at 7:45 PM / IP Logged
I was orginally building a sealed enclosure and I was recommended two Eclipse 10", but I decided to go ported. I have exactly 2.06cu,ft in a custom 3/4 MDF box made for a pair of 10"(interior mounted). The interior is  mirrored plexi(no fill),and the front is 3/4 plexi. I am using two fosgate 500s amps which will push 500w into 4 ohms. type of music will be mainly rock and hiphop.
I need speaker recommendation.
Port length and diameter.
chas
boricuaso
Copper - Posts: 50
Posted: March 22, 2005 at 8:19 PM / IP Logged
i think it would be easyer if you norrow it down to the brands you like, and then check the spec of the subs.
like i know for a fact that rockford fosgate has subs that only requier between  0.75 and 1.5 FT3.
10" subs are usualy very good for rock, and it beeing a ported box with 2 10" it should be greate for hiphop.
later.
boricuaso
Copper - Posts: 50
Posted: March 22, 2005 at 8:22 PM / IP Logged
when it comes to port lenght and diameter first you need to select the sub look at the spec's and then you get the port dimentions. well  at least i think!!!
later.
Drocay
Member - Posts: 21
Posted: March 23, 2005 at 9:15 AM / IP Logged
Well i'm really likeing Alpine type R's lately, i've only heard the 12's but the tens should be just as good.
