97 grand prix
ksutton
Copper - Posts: 94
Posted: March 27, 2005 at 10:01 AM / IP Logged
looking for a dei wire info on this car if anyone can help
swamprat323
Gold - Posts: 1,335
Posted: March 27, 2005 at 11:45 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
|       POWER LOCK|lt. blue            |- |driver kick panel           |
|     POWER UNLOCK|white               |- |driver kick panel           |
| PARKING LIGHTS +|brown               |   |at switch                   |
|       HEADLIGHTS|yellow              |+ |at switch                   |
|     DOOR TRIGGER|tan and dark blue   |- |*1                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |under rear deck             |
|TRNK/HTCH RELEASE|BLACK/ white        |+ |at switch                   |
| FCTRY ALARM ARM|arms on lock *2     |- |drivers kick panel          |
|FCTRY ALRM DISARM|ORANGE / black        |- |DKP 32 pin plug pin 5       |
|       TACHOMETER|PURPLE / white        |   |ECM under hood              |
|      SPEED SENSE|dk.green            |4 |*3                          |
|       BRAKE WIRE|white               |+ |stop light switch           |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|gray               |+ |steering column             |
| LF WINDOW UP/DN|dk. blue - brown    |A |LF window motor in door     |
| RF WINDOW UP/DN|lt. blue - tan      |A |drivers kick panel          |
| LR WINDOW UP/DN|dk. green - purple |A |drivers kick panel          |
| RR WINDOW UP/DN|lt. green - purple |A |drivers kick panel          |
Notes:
*1 The tan is located in the drivers kick and catches only the drivers door. The dark/blue is located in the passenger kick panel and catches all other doors, must diode isolate these wires.   *2 The door trigger must be active to allow the factory alarm to arm. *3 Located at a 10 pin plug on the front of the drivers strut tower. There are two dk.green wires there, use the one in the corner of the plug.
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
