latching relay for fog lamps
rubenoff
Posted: April 06, 2005 at 8:12 PM / IP Logged
Would like to have the fog lamps operate from the park lamp operations
so fog lamps can be used alone with tail park and marker lamps, or with low beam as desired, by pulling the light switch out to headlamps
But would like the fog lamps to latch with a push button fed electrically from the parklamp circuit ,
 and become unlatched  when any of the following operations occur
(A) Operator pushs the fog lamp button      ( on or off as required )
(B) Operator selects high beam
(C) vehicle is shut off for the night
Reasons for request is to prevent fog lamps from defaulting to on and becoming propped to on when vehicle is started and operator forgets to shut off fog lamps when vehicle is parked for the night,
and left on with low beam when the weather is clear
The system causes operator to have full control of the fog lamps and respects the eyes of the oncoming drivers
and be require driver  to manually reselect fog lamps when required
after starting the vehicle, after fog clears and high beam is selected
on and off when required
bj
hotwaterwizard
Silver - Posts: 1,350
Posted: April 09, 2005 at 12:35 AM / IP Logged
latching relay for fog lamps - Last Post -- posted image.
Instead of hooking to HOT hook to the Low  Beam wire in that spot. Power the Fog light coil with this circuit as the load.
Here is how it works. This circuit will get it's power from the low beam. when you push the start button the fog lights will come on. when you switch the high beams off the low beam goes out and the circuit looses power and shuts off the fog lights. When you switch back to low beams the fog lights will be off until you push start again. At any Time you can shut off the Fog lights by pushing the Stop button.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
ff-mike
Copper - Posts: 199
Posted: April 13, 2005 at 9:15 AM / IP Logged
John
He wants them to come on with the parking lamps.
hotwaterwizard
Posted: April 16, 2005 at 12:18 AM / IP Logged
Then hook the wire to the parking lamps.
Stockton California
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
