2001 mercury Grand Marquis
Welcome Guest :)
Fatkid
Member -
Posted: April 30, 2002 at 8:41 PM / IP Logged
I need the alarm wiring diagram for a 2001 mercury grand marquis
fatkid
Too Dark
Member -
Posted: April 30, 2002 at 8:49 PM / IP Logged
I can get it off my program in the morning when I go to the shop, if you do not have it yet. I will email it to you if I can get your email.
knedrager17@hotmail.com
scss
Member -
Posted: May 01, 2002 at 12:31 AM / IP Logged
Hey fatkid whats your email. i will email diagram
Jando
Security Specialist
If its a Ford Dont do it
Moderator -
Posted: May 01, 2002 at 4:58 AM / IP Logged
Mercury | Grand Marquis | 1996-2002 |
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | WHITE/ PINK | IGNITION SWITCH HARNESS |
Ignition #1: | | | BROWN / PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | | PINK/BLACK | IGNITION SWITCH HARNESS ** |
Ignition #3: | | | GRAY / YELLOW-2WIRES | IGNITION SWITCH HARNESS ** |
Accessory: | | | BLACK/ L GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | | L GREEN (+) | 16 PIN CONNECTOR IN DR. KICK PANEL |
Tach Signal: | | | TAN/L GREEN & TAN/BLUE | AT COIL PACK ON FRONT OF ENGINE * |
Parking Lights: | | | BROWN (+) | AT LIGHTING CONTROL MODULE *** |
Headlights: | | | RED / YELLOW (+) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | N/A | IN SCHEMATICS |
OEM Alarm Arm: | | | N/A | NO OEM ALARM PRESENT |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * 1996 4.6L Engine Has 2 Coil Packs On Front Of Engine.TAN/L GREEN & TAN/BLUE At One Coil Pack, TAN/WHITE & TAN/ORANGE At Other Coil Pack. Each Of These Wires Is A 2 Cylinder Signal. ** Ford Ignition Switch : High Current Draw |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | L GREEN (2), BROWN (2) | & YELLOW IGNITION SWITCH HARNESS |
Starter Kill: | | | WHITE/ PINK | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | | BROWN / PINK | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | BLACK/ L BLUE (+) | 12 PIN CONNECTOR IN PASS. KICK PANEL |
OEM Horn: | | | YELLOW /GREEN (-) | STEERING COLUMN HARNESS |
Power Lock: | | | PINK / YELLOW | EITHER KICK PANEL **** |
Power Unlock: | | | PINK/L GREEN | EITHER KICK PANEL **** |
Trunk Release: | | | PURPLE / YELLOW (+) | 3 PIN CONN. IN DR. KICK PANEL |
Alarm Input Wire: | | | BLACK/ L BLUE (+) | 12 PIN CONNECTOR IN PASS. KICK PANEL |
Notes: | | *** Lighting Control Module (LCM) Located Behind Driver Dash. WHITE/ BLACK (+) Wire At Headlight Switch Can Also Be Used For Parking Lights. **** Without OEM Keyless Entry- Reverse Polarity Door Lock , With OEM Keyless - Positive Pulse Door Lock |
Monday, June 3, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
