can jbl600.1 run JL subs
accord_coupe01
Member - Posts: 12
Posted: May 13, 2005 at 6:08 PM / IP Logged
Can I use the JBL 600.1 amp to run:
JL audio 10W6v2 preferably or
JL audio 10w3v2
will it be sufficient and the ohm has to work
stevdart
Platinum - Posts: 5,816
Posted: May 13, 2005 at 8:10 PM / IP Logged
Your title says "subs" but you don't say if you are using one, two or more.  So how many are you using?
Lthlquicksilver
Member - Posts: 47
Posted: May 13, 2005 at 9:06 PM / IP Logged
That amp should be able to run two w3's and one w6
Muscle Cars Don't Just Look Good, But They Can Sound Good Too...
1971 Chevelle SS
accord_coupe01
Member - Posts: 12
Posted: May 14, 2005 at 2:56 AM / IP Logged
no, just one sub
I thought a w6 is a 4ohm only setup and the amp can only push 300 watts at 4ohm where the sub is 400 rms is that healthy for the equipment?
a w3 can be ran at 2,4,6 ohm, and at 2 ohm the amp pushes 600 watts for a 300 watt rms sub
Lthlquicksilver
Member - Posts: 47
Posted: May 14, 2005 at 3:30 AM / IP Logged
If I recall correctly, w6's are dual voice coil and can be dual 2 ohm or dual 4 ohm.
1971 Chevelle SS
stevdart
Posted: May 14, 2005 at 3:42 AM / IP Logged
They're both dual voice coil subs.  The W6v2 is dual 4 ohm, which will wire to either 2 ohm or 8 ohm.  The W3v2 is DVC 2,4 or 6...which gives you, depending on which model you get, the wiring options of the W6v2 plus:  either 1 ohm or 4 ohm with the DVC 2;  either 3 ohm or 12 ohm with the DVC 6.
300 watts is healthy power  for either one of those subs.  The 10W3v2 DVC 2 ohm would be a good matchup, whereas you would have to run the amp at a 2 ohm load (never mind the 8 ohm option) to use the W6, which would be too much power for it.
http://www.jlaudio.com/subwoofers/10w3v2.html
http://www.jlaudio.com/subwoofers/10w6v2.html
Wiring is shown in the linked PDF manuals.
If you choose to add another sub later, you can use that amp to power two 10w3v2 DVC 2's at a 2 ohm impedance load for about 300 watts to each sub... adding about 6 decibels.
accord_coupe01
Member - Posts: 12
Posted: May 14, 2005 at 3:55 AM / IP Logged
thanks guys ...sucks being a noob
customsuburb
Gold - Posts: 1,813
Posted: May 14, 2005 at 10:05 AM / IP Logged
The 10" 2 ohm DVC W3v2 will work the best with that amp. And if you want more volume in the future you can buy another and wire them to present a 2 ohm load to your amp. Each sub would then receive 300 watts continuous.
1 2 ohm DVC sub, 300 watts continuous
can jbl600.1 run JL subs - Last Post -- posted image.
two 2 ohm DVC subs, each recieves 300 watts continuous
accord_coupe01
Member - Posts: 12
Posted: May 14, 2005 at 2:50 PM / IP Logged
I just saw a good deal on an new JL8w7 on one of the honda forums I'm thinking of jumping on that, will it work with this amp and I never heard how an 8" sub sounds I love the sound of  a 10" is it worht it?
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
