Fiberglassing my system
hellbilly007
Member - Posts: 20
Posted: June 05, 2005 at 9:01 AM / IP Logged
I didn't pay close enough attention to see that he was using the foam as a mold. I was just going off a statement he had said. Saying that he used foam so the trunk wouldn't rattle. I wan't trying to be a p***k, only wanted to help.
Slowly but surely working towards something. Not sure what though.
nikel
Member - Posts: 10
Posted: June 05, 2005 at 10:51 AM / IP Logged
hey there
what did it cost you so far?
mi_what
Copper - Posts: 208
Posted: June 05, 2005 at 10:57 AM / IP Logged
No it's all good, I thought that you were trying to suggest using dynamat as a mold...I read later that he did say something about his trunk rattling.
turtleturtle
Copper - Posts: 71
Posted: June 05, 2005 at 11:05 AM / IP Logged
It cost me about $20 so far.  I was the foam to the fiberglass would not rattle against the box and the trunk moldings.  And it was much easier to create the shape that I wanted.  The box is bolted down, and I do not have anything back there, except the air tank, air compressor, and air release valves.  My trunk itself doe snot rattle, just the fiberglass.  I had made a box a while ago, but it cracked.  I did not use enough glass.  This one is going to be about 5-7 layers.  I already got 2 layers in there now.
"...am I not Turtley enough for the Turtle Club?"
05honda
Copper - Posts: 100
Posted: June 12, 2005 at 1:09 PM / IP Logged
Before you glass it....well if you havent already you might want to put somethign over the foam so that the heat from the curing fiberglass doesnt melt or deforem the foam....just a thought.....Chris
05honda
Copper - Posts: 100
Posted: June 12, 2005 at 1:10 PM / IP Logged
Before you glass it....well if you havent already you might want to put somethign over the foam so that the heat from the curing resin doesnt melt or deform the foam....just a thought.....Chris
abovestock
Copper - Posts: 247
Posted: June 13, 2005 at 2:30 AM / IP Logged
Go to alpine's websight and look at there new BMW. They use an MDF skeleton to make the shape. Maybe use something like that if your foam base does not work out. Just a sugestion. Good luck and keep us posted.
