where to attach ground wire
mthomecouple
Member - Posts: 24
Posted: June 16, 2005 at 9:33 AM / IP Logged
i have a 2000 gmc sonoma extended cab truck.
i am running a audiobahn a2x200hq amp with a kicker sub.
where would be a good ground in this truck?
seat bolt?
what about the jack plate that is welded to the back wall of the cab?
thanks in advance any help is greatly appreciated.
joe
sedate
Silver - Posts: 1,173
Posted: June 16, 2005 at 11:02 AM / IP Logged
Any place that is clean metal attached to the frame of your car is fine.
Make sure you sand off any offending paint.  Yea, I grounded my entire system to my rear-seat belt bolt.
And make sure the ground is TIGHT.  No jiggles or looseness *at all*
mthomecouple
Member - Posts: 24
Posted: June 16, 2005 at 12:15 PM / IP Logged
what if i grind down a spot on the jack mount plate will that work? that way my wire is tucked away behind my box. thanks for the help
joe
SoundAudio
Copper - Posts: 242
Posted: June 16, 2005 at 12:37 PM / IP Logged
I have used the jack mount plate as a ground location in an s-10 and it worked great.  It is spot welded to the rest of the truck cab so it is solid ground.  Good Luck!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
