2000 Honda Civic Wires, Need Bypass?
shebal
Member - Posts: 17
Posted: June 22, 2005 at 1:59 PM / IP Logged
Anyone have the wire codes for a 2000 Honda Civic? Do I need a bypass module to install a 560XV with remote start? Thanks guys.
thepencil
Gold - Posts: 1,526
Posted: June 22, 2005 at 2:24 PM / IP Logged
A bypass module is not require for your car.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Remote Start
12volts white    +   ignition harness
Starter BLACK/ white    +   ignition harness or
Notes: In 6 pin white plug behind fuse box
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Second Ignition yellow    +   ignition harness
Third Ignition
Accessory WHITE/ black    +   ignition harness
Second Accessory
Keysense
Power Lock GREEN / WHITE    -   keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock GREEN/ orange    -   keyless entry module
Lock Motor WHITE/ red      drivers kick panel
Unlock Motor blue/red      drivers kick panel
Parking Lights+ RED / black      keyless entry module
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. GREEN/ red    -   OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black    -   OEM alarm plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue      test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Wait to start
Brake Wire GREEN / WHITE    +   brake switch
Parking Brake
Horn Trigger gray    -   OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2000 Honda Civic Wires, Need Bypass? - Last Post -- posted image.
Saturday, June 1, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
