cool flip up headlights.
bassrider20hz
Member - Posts: 40
Posted: June 27, 2005 at 4:29 PM / IP Logged
today i was going out of a parking lot from a restaurant and like usual i was listening to my system loud making alarms go off.   well i saw a 1985 trans am with flip lights the alarm went off and the flip lights started to flip up and down with the alarm i thought this was cool.   does any one here know how to hook upp the flip lights to the alarm so the move with the alarm?
dare_ds69
Silver - Posts: 419
Posted: June 27, 2005 at 6:26 PM / IP Logged
the factory alarm makes the light goes up down like in toyota supras 82-93 and some other cars.cool flip up headlights. - Last Post -- posted image.
how own your mind, control your life.
MECP certified. always use a DMM
oonikfraleyoo
Gold - Posts: 1,069
Posted: June 27, 2005 at 7:10 PM / IP Logged
Don't the lights flip up when turned on? If so, making the alarm flash the lights like you normaly would should make the lights flip up and down, right?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
bassrider20hz
Member - Posts: 40
Posted: June 27, 2005 at 11:16 PM / IP Logged
i dont think that the light alone would only light up i think you have to hook up the motor not the light. but if i were to hook up the lights how would i do that.
dare_ds69
Silver - Posts: 419
Posted: June 28, 2005 at 6:30 AM / IP Logged
there is a little module under the dash that it said TIMER HEADLIGHTS usally is in a withe box there is 4 wire, one is 12v, Ground, Headlights trigger, Factory alarm wire. when the alarm goes off the factory alarm wire turn on the module and makes the headlight goes up and down.
OhioMike1101
Silver - Posts: 343
Posted: June 28, 2005 at 7:35 AM / IP Logged
Those TA.....  some I have done, when u turn on the park lights, the headlamps flip up.
bassrider20hz
Member - Posts: 40
Posted: June 28, 2005 at 12:35 PM / IP Logged
thanks for all  your replies i will try to find the module. but i dont think it has it because my car does not have a factory alarm. but it does have a aftermarket one.    thanks
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
