fiberglass foundation mold
crippled4life
Member - Posts: 8
Posted: July 13, 2005 at 4:47 PM / IP Logged
do u lay your release agent {turtle wax} before laying the tape or after the tape and before laying the chop mat?
us_test
Copper - Posts: 200
Posted: July 13, 2005 at 6:04 PM / IP Logged
the car wax will be sandwiched between whatever you are molding and the fiberglass or fleece.  I hear WD40 is a good release agent, also Pam cooking oil spray.
(1) Kenwood Excelon Head Unit KDC-X589 (24 bit Burr Brown DAC, 3 X 4 volt RCA).
(1) RF Punch 250A2 - running the components.
(1) Hifonics 6.5" Atlas Components (18db crossovers).
Poormanq45
Silver - Posts: 597
Posted: July 13, 2005 at 9:10 PM / IP Logged
Suggestion: For a really easy release you can mold in an air fitting. This will push the two apart when needed, MUCH easier then trying to do it by hand.
To answer your question. Tape first(if that's what you're using). You don't even need the tape if you do a good enough job with the wax though
us_test
Copper - Posts: 200
Posted: July 13, 2005 at 9:41 PM / IP Logged
Why not just mold a handle on the back of it (you can use a handle from Home deport made for cabinet doors)...then easily cut it with the dremmell....
crippled4life
Member - Posts: 8
Posted: July 13, 2005 at 10:33 PM / IP Logged
so wax the actual metal than lay tape than glass.......or tape than wax than fiberglass?
us_test
Copper - Posts: 200
Posted: July 13, 2005 at 10:37 PM / IP Logged
tape than wax than fiberglass.  Finish your mold and when you are done with taping shaping whatever than wax it and then fiberglass it.
crippled4life
Member - Posts: 8
Posted: July 14, 2005 at 5:43 PM / IP Logged
thanks man
