relay for remote wire
abovestock
Copper - Posts: 247
Posted: October 07, 2005 at 12:31 PM / IP Logged
We had a problem with a remote wire not putting out enough juice to turn on a Rockford Fosgate amp..  I called them and they told me that the line needs to put out at least 10v to turn it on and that if it was not that high(8.3v)to use a relay to give it what it needs.  How do I wire in this relay, what do I activate the relay with?  Thank you for you time and help.
Why do you ask if I ate paint chips when I was younger?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 07, 2005 at 1:44 PM / IP Logged
Use your remote wire from the deck to trigger the relay.
wire it like this 12v fused (10 to 15 amps) to 87
ground to pin 86
your remote turnon wire to pin 85
nothing to 87a
out to amps from 30
auex
Platinum - Posts: 5,041
Posted: October 08, 2005 at 1:25 PM / IP Logged
IMO if your remote wire isn't above 10V in the first place then there is a problem with your radio.
relay for remote wire - Last Post -- posted image.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
abovestock
Copper - Posts: 247
Posted: October 10, 2005 at 2:46 AM / IP Logged
For some reason the wire is dropping voltage when it is connected to the 4 channel amp.
abovestock
Copper - Posts: 247
Posted: October 10, 2005 at 2:47 AM / IP Logged
P.S.-Thank you very much for the detailed help.
jaxon23
Member - Posts: 25
Posted: October 10, 2005 at 10:40 PM / IP Logged
can i use the above diagram to run the remote to my amp and 2 fans (one sucking and one blowing)? when running a 12v fan to run backwards do i just wire it in reverse? .ie negative to positive and positive to negative?
palouse md
Member - Posts: 20
Posted: October 11, 2005 at 1:57 AM / IP Logged
I wanted to know what kind of deck was having the remote wire issues.  I ran into the same problem with a kenwood unit.   Yes you can wire most fans 'backwards' to 'suck',  or turn your fan around.
md
dj_mittens
Member - Posts: 7
Posted: October 18, 2005 at 2:43 PM / IP Logged
Most decks only put out about 500mV, and each amp required about 175mV to turn on. So, if you're hooking up more than two amps, no matter what head unit you have, you should use a relay.
'91 Honda Prelude
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
