voltage drop
Reeceddogg
Copper - Posts: 329
Posted: October 29, 2005 at 8:34 PM / IP Logged
at the battery my voltage is 14.3 running at idle but measured at the amps in my trunk it only 13.9 what could be the cause for this drop
xetmes
Silver - Posts: 586
Posted: October 29, 2005 at 9:28 PM / IP Logged
resistance
v = I*R, greater the current draw or resistance, greater the voltage drop
DYohn
Moderator - Posts: 10,741
Posted: October 29, 2005 at 10:51 PM / IP Logged
What size power cable is running from your battery to your amps?
bajaclawz71
Member - Posts: 45
Posted: October 30, 2005 at 12:41 AM / IP Logged
Could be wire size or a poor ground.
tronmonster
Member - Posts: 14
Posted: October 30, 2005 at 8:57 AM / IP Logged
Poor ground will not cause a voltage drop to appear like this. It has to be wire size or a connection on the hot side.
In fact, the poorer the ground connection, the higher (up to the source voltage) the voltage reading will be at the point where power is connected to a device.
Don't wanna hear your "boom-boom," just wanna hear my "weeee-yaaah-deedle-dee."
geepherder
Platinum - Posts: 3,668
Posted: October 30, 2005 at 7:01 PM / IP Logged
Not if he's measuring voltage across the pos/neg amp terminals.  A poor ground would drop some of that voltage.  That's not that bad, though- 3 tenths of a volt drop.
haemphyst
Platinum - Posts: 5,054
Posted: October 30, 2005 at 7:34 PM / IP Logged
If he is reading AT THE AMP TERMINALS, yes, there could be a volatage drop exhibited like this.
Huh? Wha...? Either I don't understand exactly what it is that you are saying, or you are saying something that is completely false. Please elaborate on this statement.
And finally, I agree that .4v drop is nothing to be concerned about, ESPECIALLY if that drop is with the system running WFO. At idle, .4v could be a sign of something quite wrong in your system.
geepherder
Posted: October 30, 2005 at 7:58 PM / IP Logged
I thought that was 14.2.  Hah.  Some math whiz I am.
Reeceddogg
Copper - Posts: 329
Posted: October 30, 2005 at 9:37 PM / IP Logged
i'm currently running two gauge to the distribution block where i took the measurement , split to six 8 gauges four go to my rockford 800aii, the other two to accy's. measurements: at idle with the amps on but the sound on mute.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
