2003 Aztek remote start
Welcome Guest :)
*theone*
Copper -
Posted: November 16, 2005 at 1:15 AM / IP Logged
Looking for wiring diagram and any tips/tricks for an 03 aztek. Planning to install an astrostart
Thanx
boomer_106
Silver -
Posted: November 16, 2005 at 8:38 PM / IP Logged
Pontiac |
| Aztek |
| 2003 - 2004 |
Remote Starter Wiring Colors and Notes |
Function | Vehicle Color | Location |
Start: | Yellow (+) | |
Ignition #1: | Pink (+) | Ignition switch harness* |
Ignition #2: | Green (+) | Ignition switch harness |
Ignition #3: | Brown (+) | Ignition switch harness*** |
Accessory: | Orange (+) | Ignition switch harness |
Brake Light: | White (+) | Brake pedal switch |
Tach Signal: | PURPLE / White (AC) | Ignition coil |
Parking Lights: | Lt.Blue (-) | Headlight switch |
Headlights: | N/A | |
Diesel Glow Plug: | N/A | |
Clutch Bypass Wire: | N/A | |
Notes: | *This vehicle is equipped with GM's Passkey III Anti-Theft system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. To program additional keys for GM PASSK-KEY III please See Note #147.**The Body Control Module (BCM) is located |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | Orange (+) | Ignition switch harness |
OEM Alarm Disarm: | Purple (-) | Pink plug at BCM** |
OEM Horn: | Black (-) | Steering column harness |
Power Lock: | RED / Black (-) | Pink plug at BCM*** |
Power Unlock: | Same wire as power lock | Pink plug at BCM*** |
Trunk Release: | WHITE/ Black (-) | Gray plug at BCM** |
Alarm Input Wire: | Blue/White (-) | Pink plug at BCM** |
Notes: | **The Body Control Module (BCM) is located at the front of the center console under the radio. ***Lock requires a negative trigger through a 470 ohm resistor. Unlock requires a straight negative trigger. See note #211 Single Wire Negative Trigger Door L |
*theone*
Copper -
Posted: November 17, 2005 at 8:49 PM / IP Logged
Thanks for the info Boomer.
boomer_106
Silver -
Posted: November 17, 2005 at 8:50 PM / IP Logged
You're Welcome. Hope it all goes good for ya.
Sunday, June 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
