2005 Chevrolet Equinox Alarm/Remote Start Wiring
cswamp44
Member - Posts: 31
Posted: November 17, 2005 at 2:54 PM / IP Logged
looking for information on an equinox planning a remote start/alarm system very soon. thanks
swampy
infinkc
Copper - Posts: 438
Posted: November 17, 2005 at 6:29 PM / IP Logged
CHEVROLET / EQUINOX / 2005 / Remote Start
12volts RED / white (x2)   +   ignition harness
Starter yellow (not for remote start)   -   PCM, blue plug, pin 23
Notes: Starter wire is not required for remote start. When the vehicle sees that the ignition wire has voltage and the two accessory wires lose voltage, it automatically cranks the starter.
The PCM is located in front of the driver strut tower, above the battery cover.
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green (required)   -   BCM, 24 pin gray plug, pin A8
Notes: The BCM is located in the center console, below the radio.
Power Lock lt. blue   +   BCM, pink plug, pin B4
Power Unlock dk. blue   +   BCM, 24 pin gray plug, pin A3
Lock Motor gray   5wi driver kick, door harness
Unlock Motor tan   5wi driver kick, door harness
Parking Lights+ brown   +   BCM, 24 pin gray plug, pin B7
Parking Lights- lt. blue   -   BCM, 24 pin gray plug, pin B3
Hazards same as turn signal wires
Turn Signal(L) lt. blue   +   steering column
Turn Signal(R) dk. blue   +   steering column
Reverse Light lt. green   +   kick panel, harness to rear
Door Trigger gray/black and tan/white   -   BCM
Notes: The driver door trigger is gray/black in the pink plug, pin B8. The passenger doors trigger is tan/white in the 24 pin gray plug, pin B5. Use both wires and diode isolate each.
Dome Supervision white   -   BCM, pink plug, pin A1
Trunk/Hatch Pin ORANGE / black   -   BCM, pink plug, pin B12
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passlock
Tachometer purple   ac   PCM, black plug, pin 61
Notes: The PCM is located in front of the driver strut tower, above the battery cover.
Wait to start N/A
Brake Wire lt. blue   +   brake pedal switch
Parking Brake lt. blue   -   BCM, pink plug, pin B5
Horn Trigger tan   -   BCM, pink plug, pin A3
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: The Passlock II wire colors are yellow, ORANGE / black, and ORANGE / white (not used).
There are 10 types of people in the world, ones that understand binary and ones that dont.
NowYaKnow
Gold - Posts: 1,217
Posted: November 19, 2005 at 12:37 PM / IP Logged
Here's a tip for the door triggers/dome supervision. Pull the drivers door sill panel. About midway down the door sill you will see wires going under the drivers seat. In the harness coming from the FRONT of the vehicle, the driver door trigger is gray/black (-). In the harness coming from the REAR of the vehicle, you have your tan/white (-) which covers the rest of the doors. Then you have your ORANGE / black (-) which covers the rear hatch. Use the 3 triggers and diode isolate them accordingly. Or diode isolate the 2 door triggers and hook the hatch to the trunk trigger on your alarm if it has one. You also have your white (-) coming from the rear harness which is your dome supervision wire.
Mike
cswamp44
Member - Posts: 31
Posted: December 22, 2005 at 9:50 AM / IP Logged
hey thanks alot.
swampy
Sunday, June 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
