check eng. light on after remote start
splicing-wires
Posted: December 06, 2005 at 5:08 PM / IP Logged
Just installed a Code Alarm remote start on a 2005 GMC Envoy. Now the check engine light is on. The light stays on when remote start is activated, and when started with the key.  I used the directechs.com wiring, checked all conections, still can't figure it out. Any suggestions?  Thanks.
05gt
Silver - Posts: 628
Posted: December 06, 2005 at 6:02 PM / IP Logged
did you remeber to hook up the second ignition wire in the vehicle
if this wire is not hooked up it will trip the check engine light and possible damage to the transmission can occur
Mike M2
Platinum - Posts: 2,652
Posted: December 06, 2005 at 6:05 PM / IP Logged
I've had the light come on just by not hooking up both accessories even. I' suggest energizing all, pink, white, brown and orange.
Mike M2
Tech Manager
CS Dealer Services
splicing-wires
Posted: December 06, 2005 at 6:50 PM / IP Logged
Hello, thanks for the replies, I did hook up both accessories and both ignition wires. The only thing I did not try is finding a 3rd heater. Do you think that may be the cause? Also, once the problem is corrected will the light turn itself off or does it need to be reset? Thanks again.
05gt
Silver - Posts: 628
Posted: December 06, 2005 at 6:53 PM / IP Logged
it will have to be reset, usually removing the neg battery wire for about 30 mins
if that doesn't work you need a scan tool to remove it
