02 chev 2500 silv diesel
thatturbguy
Member - Posts: 8
Posted: December 08, 2005 at 10:34 AM / IP Logged
looking for easiest(arent we all) location/color to connect glow sense wire on this truck.anything out of bcm that goes to light in cluster?thanks in advance.
2001 iasca idbl world finalist
guatemalanboy
Member - Posts: 18
Posted: December 08, 2005 at 11:26 AM / IP Logged
hey what kind of alarm are u using cause, if the alarm has glow plug input wire then get a timer relay like a tr7 from pc or 528t from dei and u can do the same thing without having to take the cluster or go to the bcm okay let me know if it work or if you need help.
100%Guatemalan
KarTuneMan
Platinum - Posts: 7,056
Posted: December 08, 2005 at 11:39 AM / IP Logged
This ones easy.....get it behind the guage cluster with the tach wire. wait to start is blue, tach is white!.
The cluster comes out with 4 screws, takes 3 minutes.
thatturbguy
Member - Posts: 8
Posted: December 08, 2005 at 12:14 PM / IP Logged
not using an alarm,using panic(horn output -)diode isolating so horn wont trigger,has short delay built in (gas mode),diesel mode has a 60 second delay (customer doent like that),so connecting to glow light indicator. will start as soon as the light goes out.using omega 4lx remote starter,has pit stop feature everyone likes. (allows vehicle to remain running for a quick trip into a store,etc.)thanks again Kar Tune Man!  Gary.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
