after market door locks for alarm
rugerm44
Member - Posts: 24
Posted: December 28, 2005 at 7:58 PM / IP Logged
I have a toyota tacoma.Im installing a 560xv.I have two after market lock atuators.Both have blue and green wire.I have the 451M relay harness.Can anyone explain how to wire this thing up in detail.I dont have a wired switch for the locks.I just want the alarm to pop them open and closed.Can I wire them directly to the alarm or do I need 2 relays one for each actuator and how do i wire that up.Thanks!
ruger
chris354
Silver - Posts: 253
Posted: December 28, 2005 at 8:21 PM / IP Logged
If you hsve the 451m no need  for relays just figure out which wire on the actuators has to have power to lock the doors. That wire from each of the actuators will go to the GREEN/ black of 451m. The other wire from each actuator will go to the blue/black. You will ground the BROWN / black and the WHITE/ black and hook up the PURPLE / black to 12 volt.
rugerm44
Member - Posts: 24
Posted: December 28, 2005 at 8:41 PM / IP Logged
Thanks.You explained it a lot better than the diagram that came with it.Again thanks alot.I had a crime guard that I installed on it to begin with.Came with a locking module with two relays on it.The direction were very clear with it.It worked fine but didnt have the remote start feature.Nice in winter time.
ruger
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
