fleece to fg
the rah
Member - Posts: 27
Posted: May 15, 2006 at 2:56 AM / IP Logged
when you connect your material to the actual resined hardened fg can you use staples??????????
rah2son
slimmatic
Member - Posts: 38
Posted: May 15, 2006 at 8:59 AM / IP Logged
I'm kinda confused. You have a surface that has been resined, and now you want ot cover it with fleece? Do you mean wrapping the finished product in fleece, or fleece to fiberglass the project? If you mean to wrap it, many people use adhesive spray and either staples or glue ont he back side. If you are talking about fleece for fiberglassing, if the surface has alrerady been resined, just lay your mat on that and dont worry about wrapping it in fleece. Hope that helped.
bcordell
Member - Posts: 12
Posted: May 15, 2006 at 4:43 PM / IP Logged
If you mean how to attach the fleece to the box to fiberglass it, just stretch the fleece over the box then staple it on and resin it.
xclusivecustoms
Member - Posts: 24
Posted: May 15, 2006 at 9:43 PM / IP Logged
You can't staple into fiberglass without damaging it. Use a CA glue instead.
xclusivecustomsinc.com
