Removing A Pillar Trim in 06 Mustang
likesoldjunk
Member - Posts: 6
Posted: May 25, 2006 at 8:46 PM / IP Logged
Hi,
    I'm gearing up to install an Auto Dimming mirror
with compas and thermometer in my 06 mustang coup.
The wiring requires removing the drivers side A Pillar
Trim. A casual inspection gives no clues how to remove
it without wrecking it.
     Can anyone help me out ?
Collector of Classic Mustangs, Antique Outboards, and anything else with rust on it.
torquehead
Copper - Posts: 144
Posted: May 27, 2006 at 12:15 AM / IP Logged
....seems with my Ford consultants, the same method for A-Pillar(AP) attachment hasnt changed much. It was suggested to use a plastic trim removal tool to pop the top of the AP loose first, and with an upward pull pop the lower, so appearantly there are only two plastic trim clips or pins that hold the AP in place.
Just wondering, have you joined a Ford Mustang Forum lately?  http://www.mustangforums.com/  After you join, you can ask that same question and hear the same answer I gave you......ah, but maybe not.  Good luck in your install.
NowYaKnow
Gold - Posts: 1,217
Posted: May 28, 2006 at 8:37 PM / IP Logged
From what I remember the a-pillar trim piece is pretty large and STARTS around the back of the doors. Start removing it this point.
Mike
