06 Dodge Ram w/NAV and infinity amp add
asnyder264
Posted: June 16, 2006 at 8:45 AM / IP Logged
I just purchased a new 2006 Dodge Ram with the infinity / Navigation system and plan to install an amp with 2 - 10's under the rear seat.  I've searched through the  topics, but didn't find anything specific to this system.  I'll probably attempt the install this weekend, so any warnings or info would be helpful.  I've installed many new systems, but always with an aftermarket HU that has the pre-amp outs.  Any suggestions for line converters or where to tap into the factory speakers would be a great help.
geepherder
Platinum - Posts: 3,668
Posted: June 16, 2006 at 6:27 PM / IP Logged
If I remember correctly, your amp is under the center console.  You should be able to remove the insert and get signal.  You'll see what I'm talking about.  I don't remember the colors, but you can always check at the speakers and then ohm them at the amp to verify.
Insomniacustoms
Member - Posts: 14
Posted: June 16, 2006 at 7:19 PM / IP Logged
like geep said, your amp could be under the center console, the other place i would recomend checking is behind the glove box. you should be able to tap the speaker signal for the LOC right behind the deck. i believe the wires you should be looking for are...LR +gray/light green,-gray/dark green and RR +darkGREEN/ light green,-dark GREEN/ gray
Thursday, June 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
