Newbie, FB & pods
jae_d
Posted: August 08, 2006 at 5:02 AM / IP Logged
Hey guys,i have been building sound systems for a while,but recently decided that i wanted to build a comp system.I have a mjor but tho...the is a whole in the door for a speaker,but i wanted to make pods...but again,i have no idea how to actually start...can anyone shed sum light? :s
Platinum - Posts: 12,488
Posted: August 08, 2006 at 9:03 AM / IP Logged
If there's a hole in the door what you can do to fill it is fiberglass in the crossover into the door or get a plate of some sort to fill the hole. Use your imagination when it comes to this.
Did you want to mount the pos in the kick panel ?
jae_d
Posted: August 08, 2006 at 4:19 PM / IP Logged
well,its a 4x4 so there aint really much room in the kick pans,but the is on the door.What i meant with the hole was that,behind the door panel,there is a hole in the metal(higher up models then mine have speakers here)but my fronts are in the dash.I bought a pair of 6 1/2s with seperate tweeters,but thought that i could mayby use the plugs to run a set of 3 1/2s,and have the 6 1/2s in the door,but i wanted to make a doory pod facing upwards,or am i just dreaming? :s
jae_d
Posted: August 08, 2006 at 4:22 PM / IP Logged
oh btw...forgot to mention,i have only ever used mdf...not had the guts to try FB yet,this is wots new to me
crazyoldcougar
Copper - Posts: 185
Posted: August 08, 2006 at 9:23 PM / IP Logged
there is a couple ways you build this up...
you could try to build pods that wold fit into the hole and face upward...or you can remove the inner door panel and use an MDF ring to aim your speaker then stretch fabric over the portion of the door you want to glass...and go from there..
do a quick search for door panels, there have been a couple builds floating around lately..
Fiberglass Guru.
