more matting on weak spot
mjmauto
Member - Posts: 43
Posted: August 10, 2006 at 3:38 PM / IP Logged
I fiberglassed my dash in my 1969 chevy truck , I strectched and soaked the fleece  laid a few layers of matting down and primed and sanded. .  Now I notice some weak spots.   Can I just lay some more matting over the weak spots ? Any help or suggestions is greatly appreciated.
philliphamby
Member - Posts: 18
Posted: August 10, 2006 at 8:38 PM / IP Logged
yes you can. just sand the paint and primer away from the soft spots make sure to get to the fiberglass. also make sure that you sand the spots 2-3 in. wider all the way around. make sure to use 40-80 grit sand paper so the new resin can have a good hold. put a thin coat of resin add fiberglass then another thin coat of resin. do this 2-3 times. if it is in a spot where you dont want a small hump then you can go wider and fether it out . to give it less of a hump. then use body filler to cover the sanding marks. then sand, prep, prime, and paint.
p.s. always use the thumb test before paint trust me it will save you time and money. thumb test you say??? press your thumb all around you project firmly this way you find the soft spots before its to late.
give a man a fish he will eat for a day. teach a man to fish he will eat for a lifetime.
sawhit4
Copper - Posts: 64
Posted: August 11, 2006 at 7:30 AM / IP Logged
i use the foot test.  If i cant stand on it (before its painted) witout it breaking, its not strong enough.  i weigh in at a staggering 150.
mjmauto
Member - Posts: 43
Posted: August 11, 2006 at 10:21 AM / IP Logged
Thanks for the replies.  I used the thumb test before I started sanding, I probably sanded off more than I thought I did.  Thanks for the help.
modena0
Copper - Posts: 85
Posted: August 11, 2006 at 12:56 PM / IP Logged
and if its possible to get to the other side without ruining the fit, you can always put more glass on the bottom for reinforcement.
2000 Chevrolet S10
Premier DEH-P860MP
JL Audio XR650-CSi components
Boston 4x6 splits
JL Audio 10W3v2
Alpine MRP-M350
Clarion APA-4162
mjmauto
Member - Posts: 43
Posted: August 11, 2006 at 10:45 PM / IP Logged
Thanks for the suggestions,  I will try to fix it this weekend.
