2002 Dodge Ram
markb
Member - Posts: 43
Posted: January 16, 2003 at 11:35 AM / IP Logged
Installed a remote starter on a 2002 Ram, Now the check engine light comes on. Anybody know what the right connection is for the second ign. wire? I THINK this is the problem. Any other ideas?
-Mark
Moderator - Posts: 12,488
Posted: January 16, 2003 at 12:34 PM / IP Logged
SECOND IGNITION-----------------red or RED / wht      |+  |           ignition harness      Will require a relay unless your RS unit is capable of outputting a 12 volt current to this wire.
ViperATC5
Copper - Posts: 202
Posted: January 17, 2003 at 11:09 PM / IP Logged
Ive seen this problem with an older dodge durango - by chance; did you happen to pull your tach reference wire off of an injector wire?  This is what caused the problem in the durango - problem was solved by finding another source for tach signal, and could have also been resolved by setting the remote start to check voltage (although undesirable) rather than tach
soonerfan
Member - Posts: 7
Posted: January 17, 2003 at 11:16 PM / IP Logged
I had same problem on a different  car though, it might sound simple but I unplugged the battery for twenty mintues, pluuged it back in and drove around for awhile and the light went off
jrilla
Gold - Posts: 1,498
Posted: January 18, 2003 at 5:21 PM / IP Logged
I have seen starter kill relays cause the cruise not to work on a Dodge, and hence the check engine light, but you need to have both Ignition wires so i bet that is the problem.
J Rilla
Owner/Installer
RufNUSD
Copper - Posts: 184
Posted: January 18, 2003 at 9:11 PM / IP Logged
As Velocity said energize the Red or RED / White. Small gauge off of Ignition switch. If not energized the transmission makes noise when driving.]
Prost....Mel
Someone pass me that bottle.
king244
Copper - Posts: 68
Posted: January 27, 2003 at 12:26 AM / IP Logged
why would the transmission make noise???????
Posted: January 27, 2003 at 8:37 AM / IP Logged
Some manufacturer's require the 2nd ignition to be powered up when the primary one is energized to power up the transmission computer. If the transmission computer does not turn on, the transmission may not shift properly or may not get out of a certain gear or it will rev higher in RPM's.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
