2005 Nissan Sentra Spec-V
jpinusmc
Member - Posts: 22
Posted: September 02, 2006 at 11:53 PM / IP Logged
I am looking for the alarm wiring guide for this vehicle.  Thanks in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 03, 2006 at 12:00 AM / IP Logged
 MODEL YEAR(S)
 SENTRA  2000 -2005
 KEY T-HARNESS IMMOBILIZER
  N/A   NIS-3   NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE/ RED (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+) See NOTE *1  IGNITION SWITCH HARNESS
 STARTER 2 BLACK / YELLOW (+) See NOTE *1 IGNITION SWITCH HARNESS
 IGNITION 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 WHITE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 WHITE/ BLUE (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) WHITE/ RED (+) or RED / BLUE (+)  IN DRIVERS KICK PANEL or HEADLIGHT SWITCH
 POWER LOCK GRAY (TYPE B)  @ SECU, See NOTE *2
 POWER UNLOCK PURPLE / RED (TYPE B)  @ SECU, See NOTE *2
 DOOR TRIGGER See NOTE *3  @ SECU, See NOTE *2
 DOMELIGHT SUPERVISION RED / YELLOW (-)  @ SECU, PIN 8, See NOTE *2
 TRUNK RELEASE RED (-)  @ HATCH RELEASE SWITCH
 SLIDING POWER DOOR N/A
 HORN WHITE/ GREEN (-)  @ STEERING COLUMN HARNESS
 TACH ANY WIRE BLACK/ RED, PURPLE, BLUE/RED or GRAY/RED  @ ANY IGNITION COIL
 WAIT TO START LIGHT N/A
 BRAKE RED / GREEN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  WHITE/ BLUE(-)  @ SECU, PIN 30, See NOTE *2
 ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY  TRANSPONDER @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold. NOTE *2 THE SECU (Security Electronic Control Unit) IS LOCATED TO THE RIGHT OF STEERING COLUMN. NOTE *3 ON VEHICLES WITHOUT POWER DOORLOCKS USE RED / WHITE (-) IN DRIVERS KICK PANEL. ON VEHICLES WITH POWER DOORLOCKS, USE RED (-) FOR DRIVERS DOOR AND RED / WHITE (-) FOR PASSENGER DOOR, WHEN CONNECTING TO AN ALARM SYSTEM USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, See DIAGRAM
http://www.directwholesale.net/diagrams/printpage.asp?ModelID=15286&MakeID=5
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
