What I’ve been working on
sean 371
Member - Posts: 11
Posted: September 18, 2006 at 11:00 PM / IP Logged
Fiberglass sub box for a Diamond D6 (on backorder, so I've been a little lazy about finishing it)  I have buildup pictures if anyone is interested.
Question: How should I deal with the extra fiberglass on the side?  I know I can't sand it all down because that's the seal with the MDF.  I realized you're supposed to notch the edges, but not until I had laid the first layer of glass.
What I’ve been working on - Last Post -- posted image.
Suade Door Panel Inserts on my subaru (like how the sti's come)
snhtown
Copper - Posts: 178
Posted: September 18, 2006 at 11:28 PM / IP Logged
damm that looks like its gona look good, you seem to have been stuck on the same boat i was on, i sanded it all down, then relayed some more matting where there were gaps
raun_31
Member - Posts: 21
Posted: September 19, 2006 at 10:03 AM / IP Logged
i have a ? about that suede insert how do u remove that piece because i wanna put sum suede on mines and remove that old fabric off
killer sonata
Silver - Posts: 718
Posted: September 19, 2006 at 10:18 AM / IP Logged
Sand it down flat and lay some mat on the inside creases. That will keep your glass to mdf seal. I do it all the time.
Melted Fabric
Silver - Posts: 509
Posted: September 19, 2006 at 10:26 AM / IP Logged
Good job, keep it up.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
sean 371
Member - Posts: 11
Posted: September 19, 2006 at 5:35 PM / IP Logged
Take a utility knife and cut off the heads of the heat rivets.  Then just take screws that are similar to the three that hold the panel on in addition to the rivets, and screw them in place of the rivets.  It's not that hard, the hardest part is getting the suede to sit correctly with the vinyl, because the panel is all covered in vinyl, with that cloth segment on top of that.
jlord16
Silver - Posts: 322
Posted: September 22, 2006 at 1:54 AM / IP Logged
they look great, good job
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
snotdobbs
Copper - Posts: 148
Posted: September 22, 2006 at 6:12 AM / IP Logged
you could used duraglass on the inside of the enclosure...its thick enough if you stand the box up so that the side you need to get thicker is on the ground it wont run....if you dont have duraglass you can mix sawdust and resin and apply it in the same manner...its usually a little messier becuz you kind of have to pour it in but once its kicked its solid
sean 371
Member - Posts: 11
Posted: September 27, 2006 at 2:35 AM / IP Logged
So i finished that box up, covered it in suede, and got it all installed. Sounded pretty good, but I didn't like the idea of not being able to fold down the seats and use the whole trunk, so I started over with a sealed box going in the back left corner of the trunk, this time all fiberglass.   I'm almost done glassing it, suprisingly it only took around 8 hours so far.  I plan on painting some rubberized undercoating on this instead of going with suede.  I'll start a new topic with progress/final pics when I finish it.
Aruman
Silver - Posts: 363
Posted: September 27, 2006 at 6:11 AM / IP Logged
Nice job, what color are you gonna paint it? post more pics of the finish install.
Shaking The Neighborhood
