2001 Dodge Stratus Coupe Tach Wire
shoelesscraig
Member - Posts: 43
Posted: September 27, 2006 at 3:02 PM / IP Logged
Ok, I've searched and searched, and found nothing of use on this topic.  I've read several sheets that said to look in the fuse box and the test connector, but when I open the fuse box, I see absolutely nothing but fuses.  No connectors anywhere.  I've also read about it being in a connector in front of the drivers shock tower...there is no connector in front of the drivers shock tower.  Not sure what I'm missing.  Someone who has done this please help out.
jaurora
Silver - Posts: 429
Posted: September 27, 2006 at 3:19 PM / IP Logged
I did my girls 02 stratus R/T coupe and ran into a similar problem. I ended using one of the fuel injector wires. Use the wire that is not the common color for each injector. Hope this helps.
MECP certified (If it really means anything)
Jeremy
Chris Luongo
Platinum - Posts: 3,746
Posted: September 27, 2006 at 5:11 PM / IP Logged
Well, on the Mitsubishi Eclipse, I remember that the instrument cluster isn't hard to remove, and if you test all the wires at the back of the cluster, you'll find tach there.
Not sure how difficult pulling the cluster will be with a Sebring coupe, but it is the same car, so the wire should be back there.
caraudio904
Copper - Posts: 115
Posted: September 28, 2006 at 3:26 AM / IP Logged
If you go to the fusebox under the hood, it is the T-Shaped plug, on the top left of the plug, the wire under the terminal is WHITE or WHITE/ RED. It can help to make a cleaner install but injector coil is he first one seen usually
Southern Stylez
Jacksonville, FL 32218
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
