Fiberglass Dash
voodoo clown
Posted: October 19, 2006 at 11:12 PM / IP Logged
I was wondering if anyone can tell me when you make the skeleton part of the dash and fiberglass it, do you remove the skeleton part of it after many layers of fiberglass have dried or keep it still attached when installing it.
juniorxs
Member - Posts: 26
Posted: October 20, 2006 at 4:42 AM / IP Logged
from the ones i have seen, it stays as part of the dash.
voodoo clown
Posted: October 20, 2006 at 11:25 PM / IP Logged
thanks juniorrxs. I kinda thought it would stay in for structural purpose but wasn't really sure.
jlord16
Silver - Posts: 322
Posted: October 21, 2006 at 12:08 AM / IP Logged
You colur make the skeleton removable but it would be harder and theres really no point in doing it
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
crazyoldcougar
Copper - Posts: 185
Posted: October 21, 2006 at 1:57 PM / IP Logged
it wouldnt be that hard to make removable...just cover it in tinfoil really well before you stretch your fabric...
one of the problem's is there are usually about 500 staples holding your faric to the framework...that you would have to break free with out damaging the dash..easiest way is to twist the ribs with a pair of pliers/ vicegrips...
and second...your frame is usually used to mount to the existing mounting points in the car...
with a fiberglass dash weight reduction isnt really your goal so much as custom curves...so the weight of the ribs is really insignificant anyway...
Fiberglass Guru.
