Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | White | In ignition switch harness | + |
IGNITION | BLACK / YELLOW | In ignition switch harness | + |
ACCESSORY | BLACK/ red | In ignition switch harness | + |
STARTER | BLACK/ white | In ignition switch harness | + |
KEY SENSE | RED / white | On 16-pin green connector above driver's kick | - |
| | This is the factory alarm connector and is present even if vehicle has no factory security. |
TACH SIGNAL | Blue | At tach test connector | AC |
| | This plug is located on the passenger side of the engine compartment between the battery and the headlight. Set your remote starter for 4 cylinders. |
FUEL INJECTOR | Opposite of Yellow/black | At any injector on engine | AC |
LOCK | WHITE/ blue/2 sil. Dots | On 20-pin gray connector above driver's kick | - |
| | These wires require up to 750 milliamps to activate. Some products do not have strong enough doorlock outputs for this. You may need to install relays to provide a stronger ground. See the diagram in the available graphics. |
UNLOCK | WHITE/ GREEN/ 2 sil. Dots | On 20-pin gray connector above driver's kick | - |
DOORPIN | SEE NOTES | | |
| | GREEN is driver's door, LT.GREEN/ RED is passenger door. GREEN / WHITE catches rear doors. All wires are found on the green 16-pin connector above the driver's kickpanel. This is the factory alarm connector and is present even if vehicle has no factory security. |
TRUNK PIN | RED / 2 sil. Dots | On 16-pin green connector above driver's kick | - |
BRAKESWITCH | WHITE/ black | On 4-pin plug at brake pedal | + |
PARKLIGHTS | RED / black | In harness clipped to left side of fusebox | + |
HAND BRAKE | GREEN/ ORANGE / 1 sil. Dot | In harness running above diag. plug under dash | - |
HORN | ORANGE / 2 sil. Dots | On 16-pin green connector above driver's kick | - |
DRIVER WINDOW UP | RED / black | At 20-pin plug on switch in driver's door | REV POL |
DRIVER WINDOW DOWN | RED / yellow | At 20-pin plug on switch in driver's door | REV POL |
PASSENGER WINDOW UP | Blue/red | On 20-pin gray connector above driver's kick | REV POL |
PASSENGER WINDOW DOWN | Blue/white | On 20-pin gray connector above driver's kick | REV POL |
LEFT REAR WINDOW UP | BROWN / white | On 20-pin gray connector above driver's kick | REV POL |
LEFT REAR WINDOW DOWN | Brown | On 20-pin gray connector above driver's kick | REV POL |
RIGHT REAR WINDOW UP | Blue/orange | On 20-pin gray connector above driver's kick | REV POL |
RIGHT REAR WINDOW DOWN | BROWN / yellow | On 20-pin gray connector above driver's kick | REV POL |
HEADLIGHTS | RED / yellow | In harness on right of steering column | + |
| | You can also find a BLUE/RED (-) for the headlights on the green 16-pin security connector taped up behind dash above the kickpanel. |
VSS WIRE | Blue/white | At cruise module above kickpanel | |
TRANSPONDER IGNITION | Yellow/black | At 7-pin plug on Ignition switch assembly | + |
TRANSPONDER DATA 1 | RED / blue | Pin-2 at 7-Pin connector | DATA |
TRANSPONDER GROUND | BROWN / yellow | Pin-1 at 7-Pin connector | - |
