04 sentra spec-v alarm/remote start
faded808
Copper - Posts: 87
Posted: November 14, 2006 at 7:51 PM / IP Logged
I wanted to know if anyone can give me the wireing diagram fo the 04 Sentra Spec-v...
Also I will be installing a remote start as well, would I need any other moduel with it? any bypass moduels I will need? and also would I need relays to make the door locks work.....
thanks in advance...
faded808
Copper - Posts: 87
Posted: November 14, 2006 at 11:22 PM / IP Logged
no one has any info??
Twelvoltz
Platinum - Posts: 2,384
Posted: November 15, 2006 at 10:38 AM / IP Logged
Here is the info for the 04 Sentra, I do not know what the spec-v is.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / SENTRA / 2004 / Remote Start
[PRINT THIS PAGE]
12volts      WHITE/ red (40A)       +       ignition harness
Starter      BLACK/ white       +       ignition harness
Second Starter      BLACK / YELLOW       +       ignition harness
Ignition      BLACK/ red       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      white       +       ignition harness
Second Accessory      WHITE/ blue       +       ignition harness
Keysense      blue/white       +       ignition harness
Power Lock      gray       -       SECU right of column, pin 23
Power Unlock      PURPLE / red       -       SECU right of column, pin 35
Lock Motor      RED / black       5wi      SECU right of column, pin 15
Unlock Motor      blue/red       5wi      SECU right of column, pin 13
Parking Lights+      WHITE/ red or RED / blue       +       headlight switch or driver kick
Parking Lights-      N/A
Hazards      ORANGE / black (w/keyless only)       -       SECU right of column, pin 7
Turn Signal(L)      GREEN/ black       +       turn signal switch
Turn Signal(R)      GREEN/ YELLOW       +       turn signal switch
Reverse Light      GREEN/ YELLOW       +       driver kick, harness to rear
Door Trigger      see notes       -       SECU right of column
Notes: Vehicles with power door locks, the driver door is red in pin 29, and the passenger doors are RED / white in pin 28. Use both wires and diode isolate each.
Vehicles without power door locks, the door trigger/dome light is RED / white in the driver kick, harness to rear.
Dome Supervision      RED / yellow       -       SECU right of column, pin 8
Trunk/Hatch Pin      RED / black       -       SECU right of column, pin 38
Hood Pin      N/A
Trunk/Hatch Release      red       -       trunk release switch
Power Sliding Door      N/A
Factory Alarm Arm      lt. GREEN/ red       -       SECU, right of column, pin 41
Factory Alarm Disarm      WHITE/ blue       -       SECU, right of column, pin 30
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT GREEN / WHITE or BLACK/ yel       ac       any ignition coil
Wait to start      N/A
Brake Wire      RED / green       +       brake pedal switch
Parking Brake      yellow/black       -       parking brake switch or driver kick
Horn Trigger      WHITE/ green       -       horn switch or SECU, pin 19
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: OM-Nissan-1
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on 2.5S models. Optional on SE-R and Spec V models.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Hope this helps.
faded808
Copper - Posts: 87
Posted: November 15, 2006 at 12:51 PM / IP Logged
kool thanks.
so the only moduel that I would need it the 556uw, which is the bypass moduel for the remote start. would I need anuthing else??
Twelvoltz
Posted: November 15, 2006 at 3:02 PM / IP Logged
The U requires a spare key (or just the head of it). Maybe a couple of relays, if both accessories are needed and your second ignition output is not programmable to operate as a starter wire but nothing else special needed.
I just re-read that post and it is listing a "OM-Nissan-1" as an option for bypass, does anyone have any info on this part? Just checked the accessory manuals section of DEI's site and it is not listed. Kind of like when the 1100F was released, not much info at first, but was in the tech sheets.
starnight
Posted: December 10, 2006 at 12:05 AM / IP Logged
I wanted to know if anyone can give me the wireing diagram fo the 2001 sentra SE  with PP
please send me adresse thanksss !!
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
