2006 Honda CRV remote start wiring
SoundFX411
Copper - Posts: 153
Posted: November 16, 2006 at 6:58 AM / IP Logged
Does anyone have the wiring colors for a 2006 Honda CRV to do a Remote start and alarm. I did a search and the link was asking for a password. Any help please.
Thank You
SoundFX
thepencil
Gold - Posts: 1,526
Posted: November 16, 2006 at 8:08 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / CR-V / 2006 / Remote Start
12volts white (50A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory WHITE/ red   +   ignition harness
Keysense RED / white   -   ign harn or factory alarm plug
Notes: The factory alarm plug is a green plug to the left of the steering column.
Power Lock WHITE/ blue   -   driver kick, door harness
Power Unlock WHITE/ green   -   driver kick, door harness
Lock Motor yellow/black   5wi DKP or back of fuse box, top left
Unlock Motor YELLOW /GREEN   5wi DKP or back of fuse box, top left
Parking Lights+ RED / black   +   back of fuse box, top middle
Notes: Can also use RED / yellow (+) at the front of the fuse box, 18 pin plug, pin 15.
Parking Lights- blue   -   switch or factory alarm plug
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red   +   turn signal switch
Turn Signal(R) GREEN/ YELLOW   +   turn signal switch
Reverse Light GREEN/ black   +   frt of fuse box, 18 pin plug, pin 1
Door Trigger green (D), lt. GREEN/ red (P)   -   frt of fusebox or factory alarm plug
Notes: Use both wires and diode isolate each.
Dome Supervision GREEN/ red   -   back of fuse box, top right
Trunk/Hatch Pin red and GREEN / WHITE (glass)   -   frt of fusebox or factory alarm plug
Hood Pin yellow/red   -   pin switch or factory alarm plug
Trunk/Hatch Release BLACK / YELLOW   -   driver kick, door harness
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue   ac   test tachometer connector
Notes: The test tachometer connector is a two pin connector behind the battery.
Wait to start N/A
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake GREEN/ orange   -   Immobilizer Control Unit, pin 4
Notes: The Immobilizer Control Unit is on the ignition key cylinder.
Horn Trigger orange   -   switch or factory alarm plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface Required:
No Type:
Data Bus
Part #: IM-Honda-2
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.2006 Honda CRV remote start wiring - Last Post -- posted image.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
