hey jeff from velocity motors: need quick reply
mykrowsy
Member - Posts: 49
Posted: January 31, 2003 at 5:12 PM / IP Logged
could I be having problems because both red wires coming off of the relay bank are tied to the same place?  one guy I talked to on the phone said this could likely be the problem.  If so, what should i do?  should I run all of the power wires to the battery? or what?
also, I bought a very small siren (about 1 inch by 2.5 inces.) - where should i put it, and how do i link it with the regular siren.  I was thinking about stuffing it down one of the heat vents.
***Always happy to give misinformed advice***
mike swanson
Copper - Posts: 290
Posted: January 31, 2003 at 9:18 PM / IP Logged
run the lead const.feed for the remote start for sure !!
jrilla
Gold - Posts: 1,498
Posted: January 31, 2003 at 9:52 PM / IP Logged
Running the two wires to the same source would nor cause you to blow a fuse, because those two wires are connected inside the brain anyway.  That is how I install them on all cars that only have one power wire in the ignition harness, and I have never had any problems.  Big_Bogus' idea sounds like a way to trouble shoot though
J Rilla
Owner/Installer
mykrowsy
Member - Posts: 49
Posted: January 31, 2003 at 10:26 PM / IP Logged
those two wires aren't connected in the brain, they're both running to the 4-relay satellite bank
jrilla
Gold - Posts: 1,498
Posted: January 31, 2003 at 11:03 PM / IP Logged
OK, I was thinking of a different unit.  You still should not have a problem with them at the same point though.
J Rilla
Owner/Installer
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
