bondo stick to vinyl?
3lm3rom3ro
Member - Posts: 19
Posted: January 09, 2007 at 11:16 PM / IP Logged
ey wuz up im trying to cover all the intirior of my car and i want to paint it is  do i have to use fiberglass or can i just put the bondo on the vinyl??? thanks
wuz craking
slammed89bronco
Posted: January 11, 2007 at 10:37 AM / IP Logged
You can put bond over hte vinyl but it probobly depends...In my truck i put bondo over hte vinyl dash...which worked excellent i sanded it down and painted it......But if you mean a softer vinyl liek what i have in my door panels im not too sur ehow well that woudl work
3lm3rom3ro
Member - Posts: 19
Posted: January 11, 2007 at 6:05 PM / IP Logged
the kind of dash i got it looks kind of hard.. its like compresed. u think that would work??
wuz craking
slammed89bronco
Posted: January 11, 2007 at 7:13 PM / IP Logged
If its on your dash im pretty sure it would work...cuz every dash ive seen is hard like mine..its jsut a thin layer of the Vinyl with a thin layer of Foam under it n it worked fine for me...Only problem was sanding it but that was jsut cuz of where i used it on my dash i couldnt get in there good with a sanding block...I covered my entire dash with the bondo and sanded it down starting with an 800 Grit sand paper and painted it glossy black and it turned out excellent...looks fiberglassed...only thing i di wrogn was put a clear coat on it because that actually messed it up and dook away the shine and softened up the rest of the paint and warped it...when i redo it im not using a clear coat
