1998 pontiac grand am tach wire location
timmi
Member - Posts: 18
Posted: January 28, 2007 at 11:34 PM / IP Logged
I am having trouble locating the tach/coil wire on this 1998 Pontiac Grand Am, 2.4L.
There is a link to a picture of the engine. Can someone please describe where to look for this white wire?
2.4 L engine
Thank you!
KarTuneMan
Platinum - Posts: 7,056
Posted: January 29, 2007 at 12:38 AM / IP Logged
Like the 98 cavalier...ther should be a BIG harness that goes across the transaxle on the drivers side. Its under the air intake tube. Inside that harness you'll find ALOT of white wires. 1 of them is the tach. Get your meter out and test em till you find the one you need. I stoled this from the bulldog site. see #2 This might KINDA help...?
NOTE *1 the LIGHT GREEN/ BLACK (-) is for the DRIVERS DOOR this wire is located in the DRIVERS KICK PANEL. The PASSENGER DOOR wire is a LIGHT BLUE (-) in the PASSENGERS KICK PANEL, when connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE. to connect, See
DAIGRAM NOTE *2 the TACH wire on the 4 Cylinder engine, is a WHITE wire in the 16-Pin harness, top Right side of the engine, and on the V-6engine, the tach wire is a PURPLE / WHITE at the Coil Pack.
PS, your picture doesn't help you....or me. 1998 pontiac grand am tach wire location - Last Post -- posted image.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
