circle making tool
messiah9966
Member - Posts: 45
Posted: February 06, 2003 at 12:36 PM / IP Logged
Does anyone know of a good jig or router attachment for making circles for speaker rings?
r. clark
audiomechanic
Silver - Posts: 388
Posted: February 06, 2003 at 8:19 PM / IP Logged
the perfect circle, jeseda makes a couple and sears sells oneor if you really want you can make one your self..... not that bad to do...the perfect circle is the best I have use dso far...select product sells it for about as cheap as anyone else....installguy509
messiah9966
Member - Posts: 45
Posted: February 07, 2003 at 11:33 AM / IP Logged
you seem to be the main advice giver on this sight-  thanks for all your help, I certainly appreciate it greatly!
              Thanks installguy509
r. clark
Powerstroke
Posted: February 11, 2003 at 11:54 AM / IP Logged
www.jasperaudio.com     they sell them cheap at www.partsexpress.com
auex
Platinum - Posts: 5,041
Posted: February 11, 2003 at 5:57 PM / IP Logged
Don't know about you guys but at the shop I worked at we made our own out of 1/4 inch plexi that had a rounded bottom with a router attached to the top.  It may take some time to make and adjust but is still cheaper then to buy one.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
-=LM=-Raven
Posted: February 11, 2003 at 11:11 PM / IP Logged
I use a Shopbot CNC router  they are about $9,000.00  after complete setup.  You can see one at www.shopbottools.com
T.Carlson
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
