negative potential
peterubers
Silver - Posts: 706
Posted: May 25, 2007 at 10:46 AM / IP Logged
negative potential - Page 2 - Last Post -- posted image.
http://www.radioshack.com/product/index.jsp?productid=2062530&cp=&sr=1&origkw=momentary+switch&kw=momentary+switch&parentPage=search
This swtich is $5.00 and returns to center after you toggle up or down.
The search function is your friend.
jurb
Member - Posts: 39
Sorry that was the only schematic I could find for a switch, I'd be using a momentary switch I should have cut that part out. So for the switch side, I'd connect COM to ground and then pass that onto the relay?
I don't have any directions, I am trying to put it together using this site. I bought a Viper 350HV, and Crimestopper 610 actuators to put in power locks. Hooking the alarm to the actuators isn't a problem because the alarm comes with (-) outputs but adding a switch to generate the same sort of output threw me off.
peterubers
Silver - Posts: 706
Posted: May 25, 2007 at 10:52 AM / IP Logged
No problem.
Yes, definitely use chassis ground for COM, this will send a negative or grounding signal to either the blue or green wires coming off the DPDT momentary switch depending on whether your unlocking or locking.
jurb
Member - Posts: 39
Posted: May 25, 2007 at 11:24 AM / IP Logged
I really appreciate the help, if you are ever cursed enough to be in Saint Louis I owe you a drink.
Posted: May 28, 2007 at 5:18 AM / IP Logged
Re your relay diagramme, if you want neg outputs at 30, disconnect 87a  (dont use) and make 87 NEG input ie wire to ground.
