circuit diagram for power locks
jurb
Member - Posts: 39
Posted: May 30, 2007 at 9:18 PM / IP Logged
Can someone confirm whether or not this diagram is accurate? Thanks.
circuit diagram for power locks - Last Post -- posted image.
Ween
Platinum - Posts: 1,368
Posted: May 30, 2007 at 10:41 PM / IP Logged
no, it isn't,
the common terminal of the unlock relay should only go to the actuator.  likewise the coil of the unlock relay should only have connections to the switch and alarm (via the diode)...remove the symbol signifying a junction to the left of the coil, replace with crossed lines..  the switch should be a three position (center-off), momentary contact in the outboard positions.
mark
