enclosure infinity 10.1
alphalanos
Member - Posts: 23
Posted: August 02, 2007 at 3:59 PM / IP Logged
Im trying to design a vented enclosure with winISD but im limited by space. Maximum space is 15x20x10 inches. I cant seem to get a useable port for this sub. Should I just make a sealed box instead? Its going in a hatchback so that should help a bit on low end. Thanks.
bellsracer
Silver - Posts: 703
Posted: August 03, 2007 at 11:23 PM / IP Logged
I would go for a sealed box... Assuming you are using the Kappa seris subwoofer (most common in my area so I am just assuming), if you were to make a box that is 15x20x10 with 3/4 MDF, you would not make the required airspace for a vented enclosure even without the sub, port and bracing displacements in place.
The sealed box only needs a minimum of 3/4 cubic feet, your box before displacements is 1 1/4 cf so you should not have an issue with airspace even after displacements.
Ganbatte ne!
alphalanos
Member - Posts: 23
Posted: August 04, 2007 at 8:34 AM / IP Logged
Ok thats what I figured. Thank you.
