Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger
USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH DOOR
Domelight Super PINK (-) AT VEHICLE FUSE BOX
IN GREEN 39 PIN CONNECTOR IN FUSE BOX
LF Latch GREEN (-) IN HARNESS IN DRIVER KICKPANEL
ALSO IN GREEN 16 PIN CONNECTOR ON REAR OF FUSE BOX
RF Latch LIGHT GREEN (-) IN HARNESS IN PASSANGER KICKPANEL
ALSO IN GREEN 14 PIN CONNECTOR ON REAR OF FUSE BOX
LR Latch GREEN (-) AT VEHICLE FUSE BOX
IN GREEN 14 PIN PLUG FACING THE REAR OF THE VEHICLE
RR Latch GRAY (-) AT VEHICLE FUSE BOX
Trunk Trigger LIGHT GREEN (-) AT VEHICLE REAR FUSE BOX
REAR FUSE BOX IS LOCATED IN DRIVERS SIDE REAR QUARTER PANEL
Hood Trigger GREEN (-) AT HOOD PIN SWITCH
Alarm Disarm BLUE (-) AT DRIVERS DOOR KEY CYLINDER
TEST THIS WIRE WHILE TURNING KEY IN DRIVERS DOOR
Alarm Arm LIGHT BLUE (-) AT DRIVERS DOOR KEY CYLINDER
Parking Lights GRAY (+) IN HARNESS IN DRIVER KICKPANEL
Convenience
All Hazrd Lights GREEN (+) AT HAZARD SWITCH
Parking Brake ORANGE (-) AT VEHICLE FUSE BOX
IN WHITE 45 PIN HARNESS IN FUSE BOX
Fuel Dr Release PINK (-) AT GAS DOOR RELEASE SWITCH IN DRIVERS DOOR
Seat Mem 1 GREEN (-) AT SWITCH IN DRIVERS DOOR
Seat Mem 2 RED (-) AT SWITCH IN DRIVERS DOOR
Remote Start
Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2 RED (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (-) IGNITION SWITCH HARNESS
Speed Sense BLUE (AC) AT PCM MODULE UNDER HOOD ON PASSENGER FENDER
Brake Lights LIGHT GREEN (+) AT VEHICLE FUSE BOX
Reverse Lights BROWN (+) IN HARNESS IN DRIVER KICKPANEL
Horn ORANGE (-) IN HARNESS AT STEERING COLUMN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock RED (+) AT DOORLOCK SWITCH IN DRIVERS DOOR
PowerLock PINK (+) AT DOORLOCK SWITCH IN DRIVERS DOOR
Houston,TX
