2002 cadilac sts wiring
countyst
Posted: December 01, 2007 at 9:22 PM / IP Logged
need wiring info for 2002 cadilac seville sts remote start
ranthony
Member - Posts: 7
Posted: December 03, 2007 at 6:23 PM / IP Logged
Here is  the wiring for the caddy, also if you can get one grab yourself an idatalink bypass module model# ads-dl it will eliminate like 50% of the wires that you will need to hook up trust me it's worth it for this ride they won't sell you that omodule cause it needs to be programmed online with a special harness then get the idatalink module model # ads-tbsl-(gm) or (pl) it is already preprogrammed and slightly cheaper but you'll still have to hook up most of the wire's manually.
12 VOLTS  orange or orn/blk + ignition harness   Notes: The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module.
STARTER 1  yellow + ignition harness   Notes: The ignition harness is accessed by removing, but not unplugging the radio.
IGNITION 1  pink + ignition harness   Notes: The ignition harness is accessed by removing, but not unplugging the radio.
IGNITION 2  white + ignition harness   Notes: The ignition harness is accessed by removing, but not unplugging the radio.
ACCESSORY 1  orange + ignition harness   Notes: The ignition harness is accessed by removing, but not unplugging the radio.
ACCESSORY 2  brown + ignition harness   Notes: The ignition harness is accessed by removing, but not unplugging the radio.
KEYSENSE
POWER LOCK  RED / black - drivers door lock switch   Notes: Can also use idatalink interface module.
POWER UNLOCK  ORANGE / black - drivers door lock switch   Notes: Can also use idatalink interface module.
DOORLOCK MOTOR  gray  drivers door module   Notes: The drivers door module is located above the speaker in the drivers door.
DOOR UNLOCK MOTOR  tan  drivers door module   Notes: The drivers door module is located above the speaker in the drivers door.
FACTORY ALARM ARM  arms on lock with door open     Notes: Can also use idatalink interface module.
FACTORY ALARM DISARM  lt. green - driver door module   Notes: The driver door module is located above the speaker in the driver door.
 PARKLIGHTS POSITIVE  do not use
PARKLIGHTS NEGATIVE  BROWN / white  dim module   Notes: The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module.
HEADLIGHT  white - dim module   Notes: The RIM module is located behind the rear seat in the lower corner on the passenger side.
BRAKE  white + low in drivers kick
 DOOR PIN   -    Notes: The drivers door trigger wire is tan at the drivers door module, and the other door triggers are dk. blue at their respective door modules. idatalink module can be used
TRUNK PIN  black - rim module   Notes: The RIM module is located behind the rear seat in the lower corner on the passenger side.
DOMELIGHT SUPERVISION  gray - underdash light
 TACH  PURPLE / white  ign. coil on top of motor
VSS  dk. GREEN / WHITE  cruise control module   Notes: The cruise control module is located under the hood at the top center of the firewall.
GLOW PLUGS
 TRUNK RELEASE  lt. blue - rim module   Notes: The RIM module is located behind the rear seat in the lower corner on the passenger side.
LEFT FRONT UP/DWN  dk. blue - brown A drivers door module   Notes: The drivers door module is located above the speaker in the drivers door.
RIGHT FRONT UP/DWN  dk. blue - brown A passenger door module   Notes: The passengers door module is located above the speaker in the passenger door.
LEFT REAR UP/DWN  dk. blue - brown A lr door module
RIGHT REAR UP/DWN  dk. blue - brown A rr door module
SUNROOF LIMIT  red - sunroof motor   Notes: The sunroof motor is located to the rear of the sunroof towards the top center of the rear window.
SUNROOF OPEN/CLOSE  dk. grn - lt. grn A sunroof motor   Notes: The sunroof motor is located to the rear of the sunroof towards the top center of the rear window.
countyst
Posted: December 03, 2007 at 10:05 PM / IP Logged
thanks for the info
Sunday, June 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
