how to hard wire 12volt power harness?
namirrem
Posted: December 05, 2007 at 9:37 AM / IP Logged
I have an ipod integration system (Harman Kardon DP1US) that I'm wanting to wire directly to the power of the car, so that I don't have to use the cigarette lighter.  The wiring diagram can be found here: http://www.harmankardon.com/drive-1/diagram.aspx  but I have no idea where to connect the +12vdc, ACC, & GND wires.  In my previous head-unit installations, I've always bought a wiring harness adapter......and my amp installations have always been wired straight to the battery.  This 12-volt power harness has 3 wires that are only about 18 inches in length.  Can anyone please tell me how to do a proper install?  Any help would be appreciated.
namirrem
Posted: December 05, 2007 at 10:26 AM / IP Logged
I'm sorry - I forgot to include that this will be in a 2001 Toyota Avalon.  Can someone help me?
dwarren
Posted: December 05, 2007 at 12:02 PM / IP Logged
Get some T-Taps,
and use Blue / YELLOW as 12+ constant, Brown as your ground and Grey is ignition. Meter these leads first just to be sure. These are the colors behind the radio.
namirrem
Posted: December 05, 2007 at 12:35 PM / IP Logged
Thanks a lot for your help - but what size gauge wire will the t-taps need to fit?   What kind of meter do you use to ensure these are the correct leads?
dwarren
Posted: December 05, 2007 at 12:56 PM / IP Logged
Red colored T-Taps, not the scotch lock ones though. Looks like this.
And the wire colors are for sure, Toyota's haven't changed in years
namirrem
Posted: December 05, 2007 at 1:28 PM / IP Logged
Thanks a bunch, man.  Are the Scotch connectors the same as 3M?  Just don't want to get the wrong thing.
dwarren
Posted: December 05, 2007 at 1:58 PM / IP Logged
I prefer the ones that use a spade connector on the other wire, less likely to pull apart.
tcss
Silver - Posts: 1,623
Posted: December 05, 2007 at 2:14 PM / IP Logged
Dan I think that year Avalon has the amp behind the glovebox and the radio lead colors are differant.
There is no such thing as free installation!
dwarren
Posted: December 05, 2007 at 2:47 PM / IP Logged
This may be the case, so get the good old test light and the proper leads behind the radio, or go to the amp, which is usually below the radio and the colors I listed will be at the amp.
namirrem
Posted: December 05, 2007 at 3:08 PM / IP Logged
Yeah, guys - this is the one with the JBL factory stereo with the sub in the back (factory).  Is this going to be a problem?
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
