Bypass lockout on AVIC-N2, AVIC-D1
viet
Posted: February 17, 2006 at 12:36 AM / IP Logged
scarface78 wrote:
You can still fix it ... just drop tiny pieces of SOLDER where two PINS use to be and then connect them ... YOU HAVE TO BE REALLY CAREFULL
i did that and it didnt work, where the pins used to be is like an orange color now and just looks like the board.  i think i just screwed myself out of a bypass. :(
hybridamp
Member - Posts: 29
Posted: February 21, 2006 at 8:00 PM / IP Logged
I just used the trace-writer pen from radioshack, worked perfect and took less than 5 minutes.  Plus, I even erased it once with alochol to see how easy it would be to "unmod" it, worked perfect.
Personally, I would recommend the trace writer as a extremely easy way to do it, that is easily reversable. ;)
hybridamp
Member - Posts: 29
Posted: February 21, 2006 at 8:04 PM / IP Logged
By the way, will the new AVIC-N3 software (CNDV-60MP) work on the N2?  I'm curious as to if it would enable the newer icon style XM tuner control with better text display capabillity, since my current v1.2 N2 software is sorta lame the way it handles the XM Tuner.
And while were at it, is the AVIC-N3 even by-passable I wonder?
Page of 28
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
