98 crown vic abs light? remote start
jay3000
Member - Posts: 21
Posted: December 17, 2007 at 3:53 PM / IP Logged
Hi,
Just finish installing a remote start on my 98 crown vic(PI). I used the all connection per diagram on this site. The abs light only comes on if I remote start the car but, not if I manaully crank up the car. Am I missing something? Thx for any help!
Scytek 5100rs is the remote start I'm using.
soultinter
Copper - Posts: 170
Posted: December 17, 2007 at 4:04 PM / IP Logged
sounds like you missed an ignition or acessory wire
jay3000
Member - Posts: 21
Posted: December 17, 2007 at 4:09 PM / IP Logged
Yes. I thought that too but, I have rechecked the wiring I was thinking maybe I need to relay something or something like that. Is there anyway that I can check the alarm brain and make sure its volting right?
mauri197
Copper - Posts: 80
Posted: December 17, 2007 at 4:53 PM / IP Logged
theres is an actual wire you are missing is your second accesory powerd up some cars are powerd up tru da accesory wires check again not all diagrams are correct
extreme1
Silver - Posts: 1,070
Posted: December 17, 2007 at 4:57 PM / IP Logged
should have 3 accesory wires powered.
grey / YELLOW, BLACK/ green and pink/black.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
jay3000
Member - Posts: 21
Posted: December 17, 2007 at 5:01 PM / IP Logged
Are you saying not to power up the BROWN / pink wire. Instead power the BLACK/ green?
jay3000
Member - Posts: 21
Posted: December 26, 2007 at 10:46 AM / IP Logged
Hey guys,
i think i found something but i just need a little help with wiring up this relay. another site www.p71interceptor.com/ says i need to run an external relay due to high current draw will anybody help me with this pin out on the relay. i have a spdt relay. http://www.p71interceptor.com/remotestart/9802table.html
tedmond
Gold - Posts: 4,610
Posted: December 26, 2007 at 11:08 AM / IP Logged
the scytek should should be able ot handle the high current draw. if youare worried it might not be sufficiant wire up a relay like so.
85 - Ground
86 - Ignition input (+) from scytek remote start
87 - high current 12v
30 - to second Ignition wire.
the reason you are gettin airbag light, itsbecause you did not wire up your THIRD ignition
jay3000
Member - Posts: 21
Posted: December 26, 2007 at 11:12 AM / IP Logged
thx in advance
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
